Ccr 3650 - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 02-07-2019, 03:12 PM Thread Starter
Ccr 3650
I can only get the thing to start if I warm it up with a space heater. I have to pull it, the electric start just grinds. When it's cold it simply won't start.
Any ideas?
Thank you
Sean McMahon is offline
post #2 of 4 Old 02-07-2019, 03:28 PM
Thanks (Received): 44
Likes (Received): 114
that is a 2 cycle engine , has all old oil/fuel mix been removed from tank and carb if it has been sitting a long time.
I would clean carb, make sure to use fresh oil/fuel mixed to specs. check plug condition, or replace.
The starter is probably not engaging because of seized or frozen not being able to move or travel up the shaft. free it up and lube it it will probably be fine.
Lottstodo is offline
post #3 of 4 Old 02-07-2019, 03:32 PM Thread Starter
Thanks for the tips.
post #4 of 4 Old 02-07-2019, 04:41 PM
db130's Avatar
Thanks (Given): 16
Likes (Given): 238
Likes (Received): 198
The metal gear on the electric starter gets chewed up quite easily.
I've had one each of the following:
CCR2450
CCR3650
Snow Commander (38602)
All 3 had chewed up gears.
db130 is online now
Similar Threads
Anyone use both a CCR 2000 & a 3650 to compare. JLawrence08648 Toro Snowblowers 6 03-14-2018 07:39 PM
Got 2 free Toro 3650 dropped off to me JLawrence08648 Toro Snowblowers 1 03-14-2018 11:33 AM
Toro 3650 info ourkid2000 Snowblower Repairs and Maintenance Forum 5 02-09-2018 10:36 AM
Toro CCR 3650 Maintenance spaceace414 Toro Snowblowers 10 12-05-2016 08:05 PM
Toro 3650 Gas Octane Rating? JaCkaL829 Toro Snowblowers 12 03-29-2014 03:44 PM
