Troybuilt Skid Shoes are Too Soft - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 02-09-2019, 07:21 PM Thread Starter
The polymer skid shoes that came with my 2960xp are too soft. Basically, when I set them the washer depresses into the plastic (I'm careful not to over tighten) and they tend to slide up and I loose my 1/8" spacing. Does anyone make a harder polymer shoe that will fit my TB?
post #2 of 4 Old 02-09-2019, 07:39 PM
e.fisher26's Avatar
Thanks (Received): 50
Likes (Given): 44
Likes (Received): 69
I tighten the washer so it countersinks. Itís the only way they hold
Noma 10/29
Cub cadet 5/26 conv to 8/26
Toro 8/24
Husqvarna st230p
e.fisher26 is offline
post #3 of 4 Old 02-09-2019, 09:21 PM
Jackmels's Avatar
Thanks (Received): 194
Likes (Given): 467
Likes (Received): 811
Make Your Own Out of Plastic Cutting Board.
Jackmels is offline
post #4 of 4 Old 02-09-2019, 10:18 PM
Thanks (Given): 146
Thanks (Received): 325
Likes (Given): 429
Likes (Received): 778
Could you use larger washers, to spread the load out more? And/or maybe 2 washers stacked, so they are stiffer, and don't bend as much. Bending would relax pressure on the skid. To take the idea further, you could add a metal plate, with holes drilled to match the mounting bolts locations. The metal plate would help spread the force out even more across the plastic skid, hopefully reducing the amount that the plastic crushes over time.
Similar Threads
Need help with Simplicity Skid shoes DetroitAC Simplicity Snowblowers 1 12-31-2019 03:28 PM
How to make your own poly skid shoes JLawrence08648 Snowblower Repairs and Maintenance Forum 4 02-14-2018 10:05 PM
Skid shoes bolts issues spookyneo Snowblower Repairs and Maintenance Forum 11 07-16-2017 06:40 PM
Skid Shoes bolts issue spookyneo Snowblower Repairs and Maintenance Forum 0 07-10-2017 09:41 PM
HS80 skid shoes, auger housing sides worn away rminnehan Honda Snowblowers 3 11-02-2014 06:02 PM
