Looking for new project - recommended 2 stages - Snowblower Forum : Snow Blower Forums
post #1 of 24 Old 02-09-2019, 11:40 PM Thread Starter
Thanks (Given): 9
Hi guys,
Now that I've got the Toro single stage working was thinking about taking on another project. Was hoping for your help again.
I'm thinking about a 2-stage project. As spring comes hoping to find a cheap fixer-upper. Ideally something to take care of the EOD as my toro does a good job on all but this.Driveway isn't huge. About 4 car lenghts wide, and maybe 6 long, plus about 100' of sidewalk. Again this would ideally just be a learning project, taking things apart and exploring.
Any recommendations on size/HP? Any thoughts on brand? I was thinking about either an old Toro or Ariens, but am open to anything really. Thoughts on what I should be paying? I've seen some as low as $50 some upto $200 (for non working blowers).
I live in the Toronto area and there are almost too many choices. Was hoping to narrow down my search.
Appreciate any help.
Rutom is offline
Thanks Snowslinger thanked for this post
post #2 of 24 Old 02-10-2019, 10:25 AM
e.fisher26's Avatar
Thanks (Received): 47
Likes (Given): 43
Likes (Received): 59
On a parts availability aspect, I'd say 8+hp MTD/yard machines. Probably the cheapest you would find also. Easy to learn basic operation with how they are built.
Sent from my iPad using Tapatalk
e.fisher26 is online now
Thanks Rutom thanked for this post
post #3 of 24 Old 02-10-2019, 10:30 AM
Thanks (Received): 202
Likes (Received): 738
I personally like the Ariens 24 inch machines from 1973 to the mid 90's
cranman is online now
Likes Snowbelt_subie, tlshawks liked this post
post #4 of 24 Old 02-10-2019, 10:34 AM
Thanks (Received): 145
Likes (Received): 342
Good for you, it's worth fixing a machine up that can be gotten for a good price. As far as brand go, I'd suspect you'll find the most parts for Ariens, Toro, some of the JD, some of the simplicity will be easiest to locate. It's the blower part that you're most interested in as typically there's only 3 or 4 makes of engines regardless of branding. Also know that many manufacturers sell under different brands. Typically just some minor changes cosmetically between them.
If you have time, when you have a possible machine found, take a look at parts availability first if at all possible. See how many parts machines you can find also. It's also nice if you have the space, a parts machine in addition to your project blower is great for those missing or damaged items you might run into.
Good luck.
HCBPH is offline
post #5 of 24 Old 02-10-2019, 11:47 AM
Homesteader's Avatar
Likes (Received): 33
I’d look for Ariens 924082. They are widely available, robust, easy to work on, effective, 100% metal, and look good IMHO.
If you need something bigger i would go for a Ariens ST1028 924086 or an Ariens ST1032 924084. They have taller remote chutes, 6 blade 14” impeller and cast iron gear boxes. They are slightly larger and are the pro series from that era. If you can find one they are a great project machine.
Whatever you decide on consider buying 2 machines - a project machine and a part’s machine.
I’ve always found one machine in great condition that needs a few fixes - find another poor condition machine with the parts I need and buy both. It’s saves a lot of money when restoring these old beauties.
Ariens ST1032 924084 (ST1232)
MODS: Tecumseh OHSK120 12hp, 3" Pulley, 6 Blade Impeller Kit, Hand Warmers w/ on-off switch, 1700 Lumen LED bulb,Front Weight Bar 18.5lbs, Chute Clean Out Tool, Tire Chains, Drift Cutters, Armorskids
Homesteader is offline
Likes aldfam4, tlshawks liked this post
post #6 of 24 Old 02-10-2019, 08:02 PM Thread Starter
Thanks (Given): 9
Thanks boys. This was really helpful. I'll target the ~8hp, 24" widths. I don't think I have the space for anything bigger than a 24".
There're definitely a lot of MTDs located around here. The ariens, Toros, and JDs all seem to demand a premium price.
Was hoping for free or $50....this has been hard to find as they get scooped up fast. Thing is I can get something running for just a bit more $100-$125....but where's the fun in that. I'll keep searching. Appreciate your help guys and keep you posted.
Rutom is offline
Likes e.fisher26 liked this post
post #7 of 24 Old 02-10-2019, 08:08 PM
Guest
C equipment website has tons of parts for blowers in Canada good pricing, yardmachine n mtd are good
99698 is offline
post #8 of 24 Old 02-11-2019, 12:36 AM
Thanks (Received): 25
Likes (Received): 31
MTD are junk unless you can get something from when they still had a bit of pride (1980s). Only issue with those older machines is parts availability. I'd stick with Toro, Ariens, Simplicity, Honda etc..
SnoThro is offline
post #9 of 24 Old 02-11-2019, 02:54 AM
vinnycom's Avatar
Thanks (Given): 59
Thanks (Received): 71
Likes (Given): 57
Likes (Received): 182
the older craftsman/murray with the tecumseh motors, theyre built heavy and theyre cheap on kijiji, parts are still available and easy to learn fixing them up . with impeller mod it will throw even the heavy wet snow a fair distance
MY VIDS ON FIXIN HER UP
vinnycom is online now
post #10 of 24 Old 02-11-2019, 03:00 AM
SimplicitySolid22's Avatar
Thanks (Received): 77
Likes (Given): 74
Likes (Received): 121
MTD was not bad until after mid 90's. Like troy bilt or bolens seemed solid still then they went pretty Ehhhh...
Again all on the owner too.... Lets not knock brands we all have our loves and MTD was a staple of AMERICA for years.
RUTOM where are you located????? Maybe we can help better.
SimplicitySolid22 is offline
Similar Threads
My LED project (26" 3X HD 420CC) 2point2 Cub Cadet Snowblowers 20 01-03-2020 04:51 AM
LED Project -30 3x HD alylea Cub Cadet Snowblowers 8 12-09-2017 10:07 PM
HSS1332ATD Lighting Project tabora Honda Snowblowers 4 04-14-2017 01:19 AM
Honda HS1128TAS project YSHSfan Honda Snowblowers 34 03-26-2017 06:23 PM
Kawariens 1736/2536 Ride-on project. YSHSfan Snowblower Repairs and Maintenance Forum 9 06-23-2015 12:50 PM
