Do I need a New Gasket? - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 02-11-2019, 06:48 PM Thread Starter
Dannoman's Avatar
Thanks (Received): 18
Likes (Received): 119
I have to repair one of the bolt hole for the muffler with a helicoil. Does this usually mean the gasket should be replaced or can the old one still do the job if it's still intact?
Dannoman is offline
post #2 of 3 Old 02-11-2019, 09:37 PM
Thanks (Received): 145
Likes (Received): 342
If the gasket is still good, use it.
HCBPH is offline
Thanks Dannoman thanked for this post
post #3 of 3 Old 02-11-2019, 09:50 PM
Thanks (Given): 95
Thanks (Received): 191
Likes (Given): 73
Likes (Received): 435
Use it. Many engines today aren't even using gaskets on their mufflers.
Use Never-Seize on the bolts, exhaust, spark plug, head bolts, flywheel, crank.
Likes sturgissteele liked this post
Similar Threads
MTD Pro Snow Thrower 31AE6LFH718 - Auger gearbox gasket? guttersnipes199 MTD Snowblowers 5 11-07-2018 02:10 PM
Ariens head gasket dhoyt714 Snowblower Repairs and Maintenance Forum 7 12-12-2016 06:17 PM
New gasket or can I just use permatex? pwm Snowblower Repairs and Maintenance Forum 7 08-16-2016 06:19 PM
'84 Ariens ST824: couple of maintenance + gasket questions gbkd80 Ariens Snowblowers 9 05-20-2015 03:20 PM
Tecumseh muffler gasket doesn't fit Dave C Snowblower Repairs and Maintenance Forum 5 03-01-2015 11:38 AM
