Tecumseh or Briggs? - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 02-11-2019, 09:25 PM Thread Starter
Thekidmechanic05's Avatar
Likes (Received): 18
Tecumseh or Briggs?
I’m asking this because I own both engine brands and I seem to have great luck with Tecumseh engine in cold weather. Briggs makes great vertical shaft engines, I’ve never owned a horizontal shaft Briggs. I have 5 Tecumseh horizontal shafts and they start first pull every time even below freezing. I’ve never had a vertical shaft Tecumseh engine. I personally like Briggs for lawnmowers and Tecumseh for snowblowers. What do you guys think?
Thekidmechanic05 is offline
post #2 of 9 Old 02-11-2019, 09:36 PM
Likes (Received): 344
All my blowers have had Tecumseh engines on them. Have had a lawnmower also with a Tecumseh. Now I also have a wood chipped with a 10 HP B&S on it and it works fine also. I wouldn't be afraid to use a B&S on a blower if I had an extra one and it fit.
HCBPH is offline
post #3 of 9 Old 02-12-2019, 12:18 AM
toofastforyou's Avatar
Thanks (Received): 7
Likes (Received): 61
I've had both and never had any problem with either of them of them but my personal choice would be the Tecumseh.
Claude.
2004 MURRAY BRUTE 10HP 29"
toofastforyou is offline
post #4 of 9 Old 02-12-2019, 06:29 AM
Likes (Received): 1347
I ONLY Run BRIGGS up here in the Frozen Tundra. The other one always proved itself to nothing but a GUTLESS WONDER!!!!!!!!!!!!! And That is all The MORE I AM SAYING ON THIS 1.
Likes classiccat, gibbs296, Zavie liked this post
post #5 of 9 Old 02-12-2019, 11:43 AM
Thanks (Given): 573
Thanks (Received): 748
Likes (Given): 4245
Likes (Received): 1672
I'd go for the one that fit the best and had the most power.
post #6 of 9 Old 02-12-2019, 01:14 PM
tlshawks's Avatar
Thanks (Given): 24
Thanks (Received): 41
Likes (Given): 45
Likes (Received): 248
I own 3 push mowers with Briggs (all 1990's Quantum engines), and they are the most finicky engines I own. The gas MUST be fresh (no older than a month and even that is pushing it), and even then they are tough starters.
I also own a couple 70's era Lawn Boys with Tecumseh's...and those quite frankly are turds. I keep them at my cabin knowing full well I'll bottom out on some rock and they die a quick death. But I detest those engines - those mowers are "sacrificial lambs".
Those being said...
I now own 3 early 1970's Tecumseh engines (and one 80's era Snow King) for my fleet of aged Ariens, and each one of them are 1 pull engines. Even old gas...no problems whatsoever. Granted, I never get a single snowstorm above say 9 inches and my H70/24 inch no impeller modded Ariens struggled with last night's 8 inches of wet cement - but it never came close to dying and handled it all up to a rough 18 inches of drifted/already thrown once slop.
I love those old Tecumseh's. I'll run 'em until they blow up.
tlshawks is offline
post #7 of 9 Old 02-12-2019, 01:57 PM
Dannoman's Avatar
Thanks (Given): 13
Thanks (Received): 19
Likes (Given): 50
Likes (Received): 124
I've only owned one machine - my 1999 10/28 MTD with a Tecumseh engine. Still running strong. A beauty of a beast.
Dannoman is offline
post #8 of 9 Old 02-13-2019, 04:32 PM Thread Starter
I feel like the carbs on the tecumsehs can sit for a while and still manage to fire the engine even when dirty but Briggs carbs are very vulnerable to gas deposits and dirt. Anyone with me on this?
post #9 of 9 Old 02-14-2019, 01:17 AM
Thanks (Received): 25
Likes (Received): 31
Briggs carbs are generally crazy reliable. I've brought some back that I really probably shouldn't have. They seem to do everything through 1 jet which allows for it. The only Briggs carb that I worked with and were notorious were the old Flo-Jets from L-Heads.
Tecumseh carburetors were hit/miss. Ditto for Honda. Once the low idles circuits get plugged or the metering needle inside the body got stuck it was generally game over.
SnoThro is offline
Similar Threads
"Made in the USA" versus "Made in China" sscotsman General Snowblower Discussion 308 12-01-2019 11:50 PM
Early Simplicity, Tecumseh vs. Briggs. bbaugh66 Simplicity Snowblowers 14 03-30-2019 11:19 AM
Briggs vs Tecumseh cranman Snowblower Repairs and Maintenance Forum 27 12-06-2016 07:16 PM
Tecumseh Snow King or Briggs which is better? Winter Ariens Snowblowers 49 01-17-2015 12:22 AM
Anyone have a 1 Gallon Gas tank can be Briggs or Tecumseh GustoGuy General Snowblower Discussion 5 10-20-2013 08:06 PM
