Engineering student project... Need advice :D - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 02-13-2019, 09:14 AM Thread Starter
Hello, I'm an EE student at a snowy state school and our senior capstone project is to modify an existing snowblower to become somewhat autonomous.
The first hurdle will be the construction of a turning mechanism. We think that the easiest way to do this would be to pick a self-propelled snowblower that allows for the rotation of one wheel while the other is stopped. I'm not sure if that exists, but if it had a simple differential or other mechanism built-in (we are not mechanical engineering students!) then we could build a brake system that applies to one wheel at a time and allows the other to rotate the machine. Is there anything similar to this out there? It seems that some Ariens models have something similar, called an Auto-Turn feature but the new models are out of our price range. But I think we can buy from Craigslist so any help is appreciated, including entirely new ideas.
Thanks! If anyone is interested, I can update this thread with future progress.
EE_Student is offline
post #2 of 16 Old 02-13-2019, 09:22 AM
Likes (Received): 23
sounds like fun! You will most likely have a quicker start finding a blower with powered steering levers. Just as you mentioned one wheel is powered while the other isn't. I think the autoturn would add a level of complexity that isn't needed and more difficult to overcome since it isn't always powered in one or both of the wheels :
I posted the TroyBilt (MTD) video because it was convenient but others will likely have opinions on other models that might be easier (and possibly better) to find on CL.
trellis is offline
Thanks EE_Student thanked for this post
post #3 of 16 Old 02-13-2019, 09:22 AM
Thanks (Given): 95
Thanks (Received): 192
Likes (Given): 73
Likes (Received): 436
MTD and Craftsman have them, MTD makes Craftsman snowblowers and other brand names.
post #4 of 16 Old 02-13-2019, 09:29 AM
the guts...
trellis is offline
post #5 of 16 Old 02-13-2019, 09:31 AM
e.fisher26's Avatar
Thanks (Received): 47
Likes (Given): 43
Likes (Received): 61
the to main types are a dual clutch style setup with a trigger on each handle, when the trigger is pulled that clutch disengages and the opposite wheel keeps turning. The second is like a differential in a vehicle, pulling the machine in a direction will cause the axel to turn easy in on direction. Id imagine adding servos to replace the triggers would be an easy way.
Noma 10/29
Cub cadet 5/26 conv to 8/26
Toro 8/24
Husqvarna st230p
e.fisher26 is offline
post #6 of 16 Old 02-13-2019, 10:35 AM Thread Starter
Specific question: For the second type, I would think that most normal usage works like this: the operator disengages the clutch to turn the machine around. Do you know if any models allow for such turning while the clutch is engaged? Or better yet, if that is how it normally works. Thanks. I am worried that we will get a model that is self-propelled and allows for independent wheel turning, but not at the same time.
post #7 of 16 Old 02-13-2019, 10:42 AM
e.fisher26's Avatar
Likes (Given): 43
There are 2 clutches, one on each side. Both are engaged until a trigger is pulled to release a wheel.
Noma 10/29
Toro 8/24
Husqvarna st230p
post #8 of 16 Old 02-13-2019, 10:44 AM Thread Starter
Oh, I misunderstood. Thanks
post #9 of 16 Old 02-13-2019, 12:00 PM
Thanks (Received): 145
Likes (Received): 342
I'm going to chime in here with a couple of thoughts. First off, all my blowers have solid axels so it's only based on what I've read. I'm wondering how easy it will be to turn the unit based on wheels only with the auger on the pavement. I'm wondering if it might be easier to have either a 4 wheel (like a BobCat/loader) setup or tracks? If it's 2 wheeled, you're going to have to have the auger down all the time. If it was 4 wheeled or track it might be possible to rig a means of elevating the auger housing when attempting a turn.
Just thoughts.
HCBPH is online now
post #10 of 16 Old 02-13-2019, 02:50 PM
e.fisher26's Avatar
Likes (Given): 43
In previous projects ive seem like this, without somthing to turn the front of the machine, the rear wheels need to be controlled independently 100% of the time either by electric motors or hydro setup
Noma 10/29
Toro 8/24
Husqvarna st230p
Likes Bondo 287 liked this post
Similar Threads
Looking for new project - recommended 2 stages Rutom General Snowblower Discussion 23 03-08-2019 01:16 PM
LED Project -30 3x HD alylea Cub Cadet Snowblowers 8 12-09-2017 10:07 PM
Advice on a newly acquired 10m5 Barkingshins Ariens Snowblowers 18 11-17-2015 06:20 PM
HELP - I need some advice on how to proceed - repower? Turbohvn Re-Powering 6 04-13-2015 06:02 PM
need connecting rod advice I ruined my 1128 tecumseh jh15 Ariens Snowblowers 36 02-19-2015 06:48 AM
