How Do I Install Helicoil Properly? - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 02-14-2019, 03:12 PM Thread Starter
Dannoman's Avatar
Thanks (Received): 18
Likes (Received): 119
I am about to put a helicoil in one of the bolt holes for the muffler. If the hole is already widened enough I suppose I can just use the tap to rebore the hole to accept the helicoil without drilling first. Or would that be wrong? Also, the little tab needs to be broken off but I don't want any metal shards of any kind falling into the bolt hole - so what's the best way to prevent that?
Dannoman is offline
post #2 of 8 Old 02-14-2019, 03:26 PM
e.fisher26's Avatar
Thanks (Received): 47
Likes (Given): 43
Likes (Received): 59
Iíve always just drilled and tapped a bigger hole with a bigger bolt through the muffler. Check YouTube about the helicoil
Noma 10/29
Cub cadet 5/26 conv to 8/26
Toro 8/24
Husqvarna st230p
e.fisher26 is online now
Thanks Dannoman thanked for this post
Likes Dannoman liked this post
post #3 of 8 Old 02-14-2019, 03:51 PM
JJG723's Avatar
Thanks (Received): 15
Likes (Received): 31
First the hole must be drilled to the proper oversize dimension to accept the helicoil. When inserting the helicoil turn it in reverse first and you should feel it fall into place and then slowly insert it about 1 thread below the surface. You might be able to break off the tab with needlenose pliers if you can find a pair of those small enough. They do make tangless or tabless helicoils but that uses a separate tool for insertion.
Ariens ST824 Deluxe '97 924082
Ariens ST1024 SHO '01 924106
Ariens 1332Pro '05 924516
Ariens Professional 32 '15 926039
Ariens Professional 32 '18
JJG723 is online now
post #4 of 8 Old 02-14-2019, 04:11 PM Thread Starter
Dannoman's Avatar
Thanks guys!
Dannoman is offline
post #5 of 8 Old 02-14-2019, 04:19 PM
VirginIASnow's Avatar
Likes (Given): 20
Likes (Received): 8
You could use compressed air to clean out the hole or use a small magnet.
VirginIASnow is offline
post #6 of 8 Old 02-14-2019, 04:38 PM
Thanks (Given): 95
Thanks (Received): 191
Likes (Given): 73
Likes (Received): 435
I'll agree, YOU MUST drill the hole using the correct size drill bit for the size helicoil you are going to use, 5/16" bolt most likely.
There are 3 or 4 similar systems to helicoil but different on the market. Some like the others better.
JLawrence08648 is offline
post #7 of 8 Old 02-15-2019, 10:56 AM
Thanks (Received): 145
Likes (Received): 342
Be careful of the depth you drill your hole, you can puncture a passage behind the bolt in some engines. What I've used is a proper drill then switch to a end mill bit to flatten out the bottom.
The other thing is to be sure to keep the hole centered or you'll have issues bolting up the muffler.
HCBPH is offline
post #8 of 8 Old 02-15-2019, 11:52 AM
Likes (Received): 9
MSB1766 is offline
Similar Threads
hinnese heated grip install not heating up?? 1132le Ariens Snowblowers 4 10-12-2018 04:25 PM
2017 2x26 Heated Grip Install EnthuzedMag Cub Cadet Snowblowers 5 09-03-2018 03:39 PM
Pull cord on Tecumseh not functioning properly Habs2611 Snowblower Repairs and Maintenance Forum 5 12-18-2016 10:56 PM
How to Properly Stow Your Snow Blower Administrator Homepage News 0 11-02-2016 12:10 PM
