Lifting blower by handlebars? - Snowblower Forum : Snow Blower Forums
post #1 of 29 Old 02-14-2019, 05:36 PM Thread Starter
Snowslinger's Avatar
Likes (Given): 49
Likes (Received): 9
The step up to get in my shed is about 10-12Ē off the ground. When putting it away I found it easier to roll the blower up to the shed and tilt the auger housing up until itís sitting inside the shed and then just lift the whole weight of the back of the blower up on that pendulum and then scoot side to side until the wheels are in.
It feels solid when I do it but are those bolts and that design holding the handlebars designed for that type of torque?
1999 MTD E662E 24Ē with 10HP Tecumseh Engine.
Snowslinger is offline
post #2 of 29 Old 02-14-2019, 05:47 PM
Thanks (Received): 44
Likes (Received): 114
because I am cheap and do not like to put more strain on my back than necessary , I would grab an old pallet and cut one end to make a ramp then cut blocks to required height to meet door and drive it up.
Lottstodo is offline
Likes Snowslinger liked this post
post #3 of 29 Old 02-14-2019, 05:52 PM
sturgissteele's Avatar
Likes (Given): 24
Likes (Received): 8
I would think it wouldn't hurt. I'd do it, if needed.
Sent from my moto x4 using Tapatalk
Peace & All Good!
Honda 2015 HS928K1WA 28"
"She's a beaut, Clark! A beaut!"
sturgissteele is offline
post #4 of 29 Old 02-14-2019, 06:38 PM Thread Starter
Likes (Given): 49
Likes (Received): 9
I have a little ramp built but sometimes - like today, Iíll pull it out and let it sit in the sun or clean it off or whatever and donít necessarily want to start it up just to drive it 2í back in the shed. Plus itís sometimes slippery and I havenít yet run some kerfs across it to help with that.
post #5 of 29 Old 02-14-2019, 06:43 PM
oneacer's Avatar
Thanks (Received): 140
Likes (Received): 507
Build a ramp , pressure treated .... 4x4 coming off shed, probably 3 or 4, 4 ft lengths, hanging on joist hangers also .... then some 3/4 p.t. boards crossing over them.
oneacer is online now
post #6 of 29 Old 02-14-2019, 06:59 PM
To answer the question, that will be, yea it is ok until they break. Unfortunately metal gets weaker the more times it is stressed in one location and as well add in some rust on the inside and you increase the chance of something happening.
The handles have been engineered to accept the downward pressure needed to operate it for such as turning or backing up or motoring forward.
The weakest point will be where the first bolt hole is on the handle towards the operator where it is attached to the frame.
Thanks Snowslinger thanked for this post
Likes Bondo 287 liked this post
post #7 of 29 Old 02-14-2019, 07:04 PM Thread Starter
Likes (Given): 49
Likes (Received): 9
Okay thanks. I thought there may have been the chance that they would be designed for this torque.
post #8 of 29 Old 02-14-2019, 07:07 PM
Thanks (Given): 19
Thanks (Received): 48
Likes (Given): 107
Likes (Received): 221
Buy a set of these and attach boards 2X8's or 2x10's. You can screw to floor of shed and leave them there if door closes properly or leave them loose and remove them when not needed
ID:	153549   Click image for larger version
russ01915 is offline
Thanks Snowslinger, SimplicitySolid22 thanked for this post
Likes SimplicitySolid22 liked this post
post #9 of 29 Old 02-14-2019, 09:10 PM
Thanks (Given): 28
Thanks (Received): 25
Likes (Given): 180
Likes (Received): 41
Ive had the handle on the right side of my 2008 honda HS928 break under normal use. So in my opinion, do not put undue stress on the handles. I repaired the handles myself in my shop. The price I was quoted for a new set was $300. + So Im a bit more conscious of the stress I apply to the handle bars.
Prime is offline
post #10 of 29 Old 02-14-2019, 09:22 PM
WVguy's Avatar
Thanks (Received): 42
Likes (Received): 166
I have a set of those I've been using since 1986 (33 years) to get stuff in/out of my pickup truck, they still work fine. Cheap, quick & easy, what's not to like?
WVguy is offline
Thanks SimplicitySolid22 thanked for this post
Similar Threads
How to Properly Stow Your Snow Blower Administrator Homepage News 0 11-02-2016 12:10 PM
My NEW Hondas >>Mostly Blower Info! BeerZman Honda Snowblowers 13 11-17-2014 04:10 PM
Cover options for a Craftsman snow blower? cgwaters Craftsman Snowblowers 26 05-09-2014 08:31 AM
Honda HS520KAS Single Stage Snow Blower - Review steeve725 Snowblower Reviews 0 02-27-2014 05:44 PM
