Compression test - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 02-16-2019, 02:21 PM Thread Starter
Harry Doyle's Avatar
So I bought a compression test kit form Amazon. Im getting only 23psi on a cold Tecumseh lh318sa. It's a 9hp snow king.
Is this legit? I understand these engines have a pressure release on the camshaft to allow for easier starting.
*UPDATE**
I tried the test again using the electric start. I'm hitting 80psi.
Harry Doyle is offline
post #2 of 3 Old 02-16-2019, 03:29 PM
Thanks (Given): 145
Thanks (Received): 324
Likes (Given): 429
Likes (Received): 775
That's lower than I've gotten on my Tecumsehs, I've had 40-45 with the pull start. Jumping to more like 80 with the electric start. One was an OHV, after just setting valve clearances, and confirming the bore was ok.
Compression releases complicate the readings. You could check your valve clearances. If the exhaust valve clearance is small, the compression release might be opening the valve a bit too far.
Make sure you aren't using any unnecessary adapters. Your want to minimize the air volume that you're adding, by adapters, hose extensions, etc. Any added volume (even the tester itself) will give artificially lower readings then what the cylinder sees.
And keep pulling until the reading stops rising, don't just pull once, for instance.
post #3 of 3 Old 02-16-2019, 04:15 PM
Thanks (Given): 95
Thanks (Received): 194
Likes (Given): 74
Likes (Received): 449
I agree with RedOctobyr 100%, I can't add anything, just confirming what he said to you other than as long as its starting fine, it's ok. When the valves, especially the intake, starting becomes harder.
JLawrence08648 is offline
Similar Threads
compression test snowhound Snowblower Repairs and Maintenance Forum 2 11-21-2018 08:47 PM
Tecumseh Snowblower Eng 4.5HP Compression mikulskn Snowblower Repairs and Maintenance Forum 4 08-24-2014 05:23 PM
First Snowblower mstrlucky74 Snowblower Repairs and Maintenance Forum 25 01-22-2014 09:20 PM
