Heated Grips - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 02-19-2019, 02:26 PM Thread Starter
Thanks (Given): 7
Likes (Given): 30
Heated Grips
I have seen articles and videos on installing heated grips on snowblowers that don't have them from the factory. But it seems to me they would not be all that effective, because the auger and drive levers come down on top of them and keep your hands from touching the grips except for your fingers.
Do folks find them effective? It seems to me like heated gloves would be a better way to go.
The other thing I have noticed is that for either heated grips or heated gloves the charging systems on these blowers are likely not up to the task. For instance, the blower I have on order is a Honda, and the stator / charging system in it does not look like it has enough capacity to drive heated grips or gloves. I know there are optional OEM and aftermarket stators that have more current capability, but most of the installs I have seen don't cover that.
michaelnel is offline
post #2 of 14 Old 02-19-2019, 02:34 PM
Likes (Received): 279
In all honesty I'm not a fan of the heated grips..... you need a power source that can drive them first off.... and really, my hands never get cold - usually sweaty! ON a snowmobile I can see it.... long rides and not working very hard. Maybe it would allow you to wear thinner gloves I guess.... ? But you can also have heated gloves with the warmer packs too....
IDK? Maybe some other variables come into play.... a really long drive or if you do it commercially maybe...? My problem is almost always how not to sweat!
post #3 of 14 Old 02-19-2019, 02:44 PM
Thanks (Received): 122
Likes (Given): 138
Likes (Received): 280
I put a Chinese kit on well, Because I could lol. But with my heavy gloves it doesnít do a lot but did notice them keeping my finger tips warm so I guess they work well enough but not a needed thing.
Dauntae is online now
post #4 of 14 Old 02-19-2019, 03:39 PM
Thanks (Given): 543
Thanks (Received): 713
Likes (Given): 4031
Likes (Received): 1548
I bought a couple of the really cheap ones off amazon or ebay and the wiring is nothing but junk. Especially the connection up at the heating element. I never bothered to install them as they just look like they wouldn't last one season and I chalked it up to not being so cheap next time. You get what you pay for. If you're going to go with aftermarket add-ons get something with good reviews.
post #5 of 14 Old 02-19-2019, 03:58 PM
tabora's Avatar
Thanks (Given): 41
Thanks (Received): 194
Likes (Given): 117
Likes (Received): 359
I just received a set of these Oxford EL801Z Cruiser grips (25mm / 1" bar size) that are made to order for the Honda HSS models that have an on-board battery (electric start). Several forum members have installed them with excellent results, and here's the video telling how: https://www.snowblowerforum.com/foru...693-post1.html
tabora is online now
post #6 of 14 Old 02-19-2019, 04:02 PM Thread Starter
Thanks (Given): 7
Likes (Given): 30
Yeah, I watched the video. He did an excellent, meticulous install. I had Oxford Heaterz on one of my motorcycles and they were the best heated grips I have ever used.
But the problem remains that the auger and drive levers are unheated and will insulate your hands from the grips except for your fingertips.
I think heated gloves would work better if you have power to heat them.
post #7 of 14 Old 02-19-2019, 04:51 PM
Thanks (Received): 24
Likes (Received): 78
I find the grips work pretty well (and if it's not below 25* or so, I often turn them off after the first few minutes to avoid my hands getting too warm). My fingers are far more likely to get cold than the rest of my hand, so the levers partly blocking the grips doesn't present an issue. But having them is definitely the difference between wearing insulated gloves vs needing mittens (with the inconvenient loss of fingers).
rslifkin is online now
post #8 of 14 Old 02-19-2019, 05:04 PM
Zavie's Avatar
Thanks (Received): 116
Likes (Given): 559
Love the heated grips on my Simplicity. When we had the polar vortex blow through here they kept my hands toasty warm. Between doing the driveway, Cul de Sac, side yard back to the utility trailer and shed, and the dog run area, I can be out quite a while. It's so nice to do everything at once. Heated grips were one of the features I didn't have on my Husqvarna so when I got a chance to sell it I did.
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is online now
post #9 of 14 Old 02-19-2019, 05:06 PM
Thanks (Given): 129
Thanks (Received): 292
Likes (Given): 387
Likes (Received): 692
I have them on my current machine, never gave much thought until we had some storms when I was clearing in windy 10-15F conditions. Suddenly they were a big help.
Yes, the levers kind of get in the way of the tops. But as was said, your fingers still get the heat, which made a big difference.
I wouldn't move heaven & earth to add them. And heated gloves (or chemical hand warmers) might be simpler, since many machines won't have the electrical capacity for them. But I *do* like having them available, they've made cold clearing more comfortable.
post #10 of 14 Old 02-20-2019, 04:23 AM
SnowH8ter's Avatar
Thanks (Received): 17
Likes (Received): 54
A variable: -25c and the wind is blowing...
Wounded 30-inch Mastercraft (MTD) circa 96
17 ST330P Husky
SnowH8ter is offline
Similar Threads
Heated hand grips and LED light Gotime Honda Snowblowers 19 03-06-2019 06:54 AM
Honda HSS1332ATD Oxford Heated Grips vmax29 Honda Snowblowers 4 12-26-2018 07:05 AM
Ariens brand heated hand grips Shaw351 Ariens Snowblowers 5 12-10-2017 02:15 AM
3x 28 heated grips issues therandomsuit Cub Cadet Snowblowers 6 11-05-2017 10:48 AM
Need Heated Hand grips ? RIT333 Ariens Snowblowers 77 02-02-2016 03:50 PM
