Old Toro (Briggs) - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 02-23-2019, 02:06 PM Thread Starter
Old Toro (Briggs)
Hi, I'm the new guy. I have a problem with my 42 year old Toro 8/26. Last year after trying to rebuild my carburetor I got fed up and replaced it. This year it has been working much better, but now my problem is that after about 25 minutes of use it stops working. I found that if I let it rest 5 or 10 minutes it would run again for 10 minutes. I spoke to a local mechanic and he suggested changing the magneto which I did yesterday. It stills stops at around the 30 minute mark. If I can get it to turn over right away if I put the choke to full, but it won't run.
I'm at a loss, what is happening?
Thanks in advance,
Graham
Here are the blower and engine numbers.
Toro 826
model 31763
serial 7000001 - 9999999
year 1977
Engine B&S
190402 0914-01 76042810
SimonsGr is offline
post #2 of 6 Old 02-23-2019, 02:20 PM
Thanks (Received): 202
Likes (Received): 738
Might be a clogged gas cap vent preventing the fuel to reach the carb as it is creating a vacuum. Try running with a piece of saran wrap over the gas tank held in place with a rubber band and poke a few holes in it for ventilation. If that works you need to clean or replace the cap.
cranman is online now
Likes RedOctobyr, classiccat liked this post
post #3 of 6 Old 02-23-2019, 03:01 PM
Thanks (Given): 137
Thanks (Received): 304
Likes (Given): 401
Likes (Received): 723
Welcome to the forum! Good advice from cranman, start with that and let us know what you find.
post #4 of 6 Old 02-23-2019, 03:40 PM
Thanks (Given): 26
Thanks (Received): 80
Likes (Given): 78
Likes (Received): 230
Have you changed the fuel lines and checked the tank for crap? My 1970's 724was doing similar, and I found fine rubber residue from an old deteriorating fuel line would slowly plug the carb, but would settle back in the bowl after standing a bit, giving similar symptoms to what you describe. (Just mine died much more quickly, but then again, hadn't been fun for 20 years, so the hose was really nasty . . .)
tadawson is offline
post #5 of 6 Old 02-23-2019, 06:51 PM Thread Starter
Yes, I changed the lines when I changed the carb, but the gas cap may be the solution. I will test that as soon as I can, we are expecting freezing rain tomorrow.
I will post back if it worked.
Thanks.
SimonsGr is offline
post #6 of 6 Old 02-23-2019, 07:09 PM
Thanks (Received): 372
Likes (Received): 1315
Put a Plastic tank on it redo all fuel lines with a inboard filter. AND THROW A FEW HAIL MARY'S to The Skies above. That what ever that gunk was has not made it to that Purdy new carb already.
Similar Threads
Replacing a Toro primer bulb with a Briggs JLawrence08648 Snowblower Repairs and Maintenance Forum 1 03-21-2018 03:30 PM
Toro POWER MAX 726TE [email protected] Snowblowers and Snowblower Parts Wanted 5 02-05-2016 09:58 AM
Toro vs. Simplicity in the $1500 segment gmazet General Snowblower Discussion 35 01-24-2016 01:05 PM
Toro, Ariens or Brute by Briggs & Stratton? MPX General Snowblower Discussion 10 01-05-2016 07:24 PM
Trading in my Briggs Stratton for a Toro Kinibo General Snowblower Discussion 6 07-22-2015 11:24 PM
