What Fuel Additive do you use? - Snowblower Forum : Snow Blower Forums
View Poll Results: What Fuel Additive do you use?
SeaFoam 18 24.32%
Lucas 1 1.35%
Star-Tron 10 13.51%
Chevron Techron 2 2.70%
Stab-Bil Regular or Marine 32 43.24%
Red Line 0 0%
Gumout 0 0%
STP Super Concentrate 0 0%
Royal Purple 0 0%
Other 11 14.86%
Voters: 74. You may not vote on this poll
post #1 of 57 Old 02-24-2019, 09:35 AM Thread Starter
Thanks (Given): 19
Thanks (Received): 48
Likes (Given): 105
Likes (Received): 220
Just wondering if you use a fuel additive and why? I use Stab-bil in every full up. Living in the Boston area, the machine can sit at times with little or no use.
russ01915 is offline
post #2 of 57 Old 02-24-2019, 09:51 AM
Thanks (Given): 24
Thanks (Received): 17
Likes (Given): 141
Likes (Received): 31
I use the Canadian Tire brand fuel stabilizer. It's probably the same thing as Sta-bil. I will occasionally use seafoam.
Honda1132 is online now
post #3 of 57 Old 02-24-2019, 09:59 AM
e.fisher26's Avatar
Thanks (Received): 46
Likes (Given): 43
Likes (Received): 59
Stabil 360
Noma 10/29
Cub cadet 5/26 conv to 8/26
Toro 8/24
Husqvarna st230p
e.fisher26 is offline
post #4 of 57 Old 02-24-2019, 09:59 AM Thread Starter
Thanks (Given): 19
Likes (Given): 105
There are three common cleaning agents used in most top selling brands, polyisobutene or PIB, Polyisobutylene amine or PIBA and Polyetheramine or PEA. Most of these are nitrogen based and act as a detergent. If a product lacks a nitrogen based additive, its cleaning ability is negligible.
PIB is typically found in Gas Treatments and some Fuel Injector/Carb Cleaners. It does a decent job of removing water and some dosage rates may keep new deposits from forming on fuel system parts but it is not strong enough to remove existing deposits and it normally requires usage with each fuel fill-up.
PIBA is normally found in Fuel Injectors. At the right dosage rate, it will provide more cleaning power to remove existing deposits, clean more parts and can have a longer interval between applications than PIB.
PEA is the cleaning agent found in any truly effective complete fuel system cleaner. It is the strongest cleaning agent available in fuel additives. It cleans better and cleans more parts than PIB and PIBA. PEA is in a league of its own and in some cases it is the only detergent that can get the job done.
Which detergent and how much of it is in the formula will determine the cleaning power of your fuel additive and the treatment interval. Basically, PIB is good, PIBA is better, and PEA is the best. The ratio of cleaning agents to other fluids in an additive will determine how well it cleans existing deposits
and prevents new ones from forming. This ratio can vary considerably by brand and product and is not always reflected in the price. However, if an additive does not contain PEA or one of the other nitrogen-based detergents, it simply is not cleaning.
Thanks RedOctobyr thanked for this post
post #5 of 57 Old 02-24-2019, 10:05 AM
e.fisher26's Avatar
Likes (Given): 43
Are you looking to clean the eng or just prep for stored gas? I use stabil for prep and sea-foam for cleaning
Noma 10/29
Toro 8/24
Husqvarna st230p
post #6 of 57 Old 02-24-2019, 10:12 AM
Digger 66's Avatar
Techron for me with a little marine Sta-bil (added to non-e) if it's going to sit for more than 30 days
Digger 66 is offline
post #7 of 57 Old 02-24-2019, 10:14 AM Thread Starter
Thanks (Given): 19
Likes (Given): 105
According to Sta-Bil:
Keeps engine running smoothly
For use in cars, trucks and small engines
Prevents corrosion, helps remove water from fuel
Cleans fuel injectors, carburetors and intake valves for better overall performance
Use at every fill up
Keeps fuel fresh for up to 24 months during storage
Eliminates the need to drain fuel prior to storage
post #8 of 57 Old 02-24-2019, 10:27 AM
Thanks (Given): 28
Thanks (Received): 25
Likes (Given): 180
Likes (Received): 41
K 100 year round. Gas line antifreeze in winter. Works for me.
Prime is offline
post #9 of 57 Old 02-24-2019, 10:41 AM
Thanks (Given): 95
Thanks (Received): 189
Likes (Given): 72
Likes (Received): 434
I only can vote for one. I use Stabil or Startron with Seafoam or Lucas or Gumout Regane.
post #10 of 57 Old 02-24-2019, 10:50 AM
aldfam4's Avatar
Thanks (Given): 245
Likes (Given): 664
Likes (Received): 123
Combined with ethanol free gas, I like Seafoam - it keeps carb and fuel lines/tank clean. No problems!!!!!
Ariens - 924086 - ST1028
Craftsman - 88934 - 10HP 28"
Toro - CCR 3650
Toro - CCR 2000
aldfam4 is online now
Similar Threads
Race Gas for the old Tecumseh Sign216 General Snowblower Discussion 55 02-04-2018 10:50 PM
Fuel Additive to Keep Carb Clean? Dannoman General Snowblower Discussion 20 01-24-2018 06:50 PM
Keep fuel in metal carb bowls and gas tanks JLawrence08648 Snowblower Repairs and Maintenance Forum 13 12-03-2017 12:02 PM
Which Fuel Should I Buy for My Snowblower? Jack28 Snowblower Repairs and Maintenance Forum 18 02-05-2017 05:25 PM
Fuel System Maintenance/Do It Or Fix It mrfixit General Snowblower Discussion 4 01-31-2017 11:09 PM
