Square vs Rounded - Discharge Chute Deflectors - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 03-01-2019, 11:28 AM Thread Starter
Homesteader's Avatar
Likes (Received): 33
I’m interested to know if the newer flat square cornered chute deflectors offer any improvement over the older rounded style.
My older rounded deflector seems to create a wider fan shaped stream than the newer square styled.
Would upgrading my deflector tighten up the steam of snow and increase throwing distance?
I already have an extra tall chute so it’s just the deflector I’m interested in. Pics attached.
ID:	154295   Click image for larger version
ID:	154297   Click image for larger version
ID:	154299   Click image for larger version
Ariens ST1032 924084 (ST1232)
MODS: Tecumseh OHSK120 12hp, 3" Pulley, 6 Blade Impeller Kit, Hand Warmers w/ on-off switch, 1700 Lumen LED bulb,Front Weight Bar 18.5lbs, Chute Clean Out Tool, Tire Chains, Drift Cutters, Armorskids
Homesteader is offline
post #2 of 4 Old 03-01-2019, 12:15 PM
Thanks (Given): 95
Thanks (Received): 194
Likes (Given): 74
Likes (Received): 449
I have both and have used both. I think the square rectangular is more directional and heavier, thicker, more concentrated, and the round does spread it out more. But I'm not switching.
post #3 of 4 Old 03-01-2019, 12:41 PM
Kielbasa's Avatar
Thanks (Received): 28
Likes (Received): 106
I ask the same type of question about the deflectors a couple of years ago. I sort of think the "flat" style deflector would give more like a ricochet type throw where the "curved" style would give a sort of swooping kind of throw.
Kielbasa is offline
post #4 of 4 Old 03-02-2019, 09:38 PM
SimplicitySolid22's Avatar
Thanks (Given): 63
Thanks (Received): 77
Likes (Given): 77
Likes (Received): 127
Originally Posted by Homesteader View Post
Iím interested to know if the newer flat square cornered chute deflectors offer any improvement over the older rounded style.
I already have an extra tall chute so itís just the deflector Iím interested in. Pics attached.
Did you add those black extenders on your tall chute???
SimplicitySolid22 is offline
Similar Threads
526 SWE Cub Cadet discharge chute control jdtbone Cub Cadet Snowblowers 13 12-01-2019 06:10 PM
Murray 8/24 loose/rattling plastic discharge chute Gta_g20 Murray Snowblowers 3 12-05-2018 09:54 AM
Round vs square chute? Ray 1962 10ML60 General Snowblower Discussion 11 01-12-2014 04:59 PM
Tip: Discharge Chute Freeze-up, Difficult Rotation EddyCurr Snowblower Repairs and Maintenance Forum 3 01-01-2014 05:14 PM
Jacobsen Imperial 826 Discharge chute needed. Will a 626 chute work? bkasmauski Snowblower Repairs and Maintenance Forum 4 02-27-2011 11:36 AM
