My john deere 1032 snowblower auger issues - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 03-02-2019, 08:08 PM Thread Starter
Im having issues with my auger running constantly, even after I disengage it. Everything looks fine, and ideas?
Sbk720003 is offline
post #2 of 5 Old 03-02-2019, 08:30 PM
Thanks (Received): 7
Likes (Received): 19
Hello Itís possible a return spring on brake system not engaging.
New Jersey, Toro 8/24, Ariens 5/22, small engine repairs
Bluejoe is offline
post #3 of 5 Old 03-03-2019, 01:09 AM
GoBlowSnow's Avatar
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 268
auger belt tensioning may be too tight.
GoBlowSnow is offline
post #4 of 5 Old 03-03-2019, 08:31 AM
Likes (Received): 344
What's been already listed plus there could be a rust build-up inside the pulley keeping the belt tractioning even when the control is released.
HCBPH is offline
post #5 of 5 Old 03-03-2019, 12:27 PM
Thanks (Given): 573
Thanks (Received): 748
Likes (Given): 4245
Likes (Received): 1672
to SBF Sbk720003
Have you pulled off the belt cover and inspected the belt and the tensioner ?? If your's is a 1032 and not a 1032D than it's an older 70s-80s JD built machine and might just need a little adjustment and checking to see if maybe the tensioner is hanging up a bit and even though you release the handle the tensioner might not be pulling away from the belt all the way. Maybe a little cleaning and lube of the tensioners pivot point might be in order. As above check for a return spring that should be pulling that tensioner away from the belt.
Similar Threads
John Deere 1032 Snowblower (Tecumseh HM100 engine) mrc00l88 Snowblower Repairs and Maintenance Forum 12 01-24-2019 08:04 PM
John Deere Model 38 Snowblower RED HORSE 76 Snowblowers and Snowblower Parts for Sale 1 03-08-2016 06:33 AM
John Deere 524 Auger Gear Justns11 John Deere Snowblowers 6 02-12-2014 02:39 PM
John Deere LX277 SnowBlower Question stttt John Deere Snowblowers 3 01-11-2014 01:32 PM
Auger swap Inthecarport Snowblower Repairs and Maintenance Forum 5 11-17-2013 09:44 AM
