2 stroke oil leak - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 03-03-2019, 03:46 PM Thread Starter
malisha1's Avatar
Likes (Received): 32
2 stroke oil leak
Hi, I have a 2 cycle Murray 4.5hp single stage. I like it a lot and it works super well with no issues so far. I would like to continue to use it for a long time with basic maintenance. I have noticed that the bottom of the engine is covered with oil. I might be incorrectly mixing the gas and oil but I wanted to know if this is normal or is there an issue? There is no blue smoke exhaust when running
malisha1 is online now
Likes Lottstodo liked this post
post #2 of 17 Old 03-03-2019, 03:48 PM Thread Starter
malisha1's Avatar
Pix
ID:	154403   Click image for larger version
ID:	154405   Click image for larger version
post #3 of 17 Old 03-03-2019, 03:59 PM
Thanks (Received): 62
Likes (Given): 63
Likes (Received): 205
have you tried wiping it off and does it come back? there should be no oil leaking from the crank case if the engine is running good. the 2 strokes require the crank case being sealed to operate properly. maybe some gas has leaked out of the carb and ran down there. hard to say. those are good little machines. i used to have one and loved it.
edit it might be coming from the exhaust now that i looked at it again. sometimes they don't always burn all the fuel and it will come out the exhaust
yardworks 31AH6WKF515
crazzywolfie is online now
post #4 of 17 Old 03-03-2019, 04:03 PM
Thanks (Given): 122
Thanks (Received): 284
Likes (Given): 371
Likes (Received): 662
For a 2-stroke, blue smoke while running is really influenced just by how much oil you have mixed in the gas. Unlike a 4-stroke, a 2-stroke's smoke amount shouldn't really change to things like worn piston rings.
It could be a worn/leaking crankshaft/crankcase seal, as crazzywolfie said. Or it could be a carburetor leak, that's allowing oil-mixed gas to drip down the engine. Then the gas evaporates, leaving just the oil. As he said, I'd clean it up, and see if it comes back.
Are there any drips from the carburetor?
post #5 of 17 Old 03-03-2019, 04:08 PM Thread Starter
malisha1's Avatar
Yes I did wipe it off and it returns. I suspect it's coming from the exhaust. In the pix I posted there a hair like cracks in the crank case. Could it be coming from there?
post #6 of 17 Old 03-03-2019, 04:08 PM
Likes (Given): 63
if it is running good then it probably isn't a seal tho. usually 2 strokes won't stay running long if a crankcase seal is leaking. to me with how dark the stuff is it looks like it is coming out of the exhaust. maybe a bad muffler gasket. my old machine use to have the muffler vibrate loose all the time. i never cared about leaks so never paid much attention to that
post #7 of 17 Old 03-03-2019, 04:14 PM
Thanks (Given): 122
Likes (Given): 371
Can you point out the possible crack(s)? They might just be casting marks, hopefully.
Some of my 2-stroke machines drip some oil from the exhaust. I'd imagine it's influenced by the oil mix ratio you're running, as well as what type of oil. My 2-stroke blower certainly has some oily residue on the plastic shroud by the muffler. Even if muffler gaskets were perfect, I'd imagine you could still get some dripping from the actual exhaust opening itself.
post #8 of 17 Old 03-03-2019, 04:37 PM
Likes (Given): 63
but if the gasket was doing its job it would seal up between the muffler and block and burn up any oil/gas residue in the muffler or spit it out the muffler instead of having it leak down the engine onto the ground.
post #9 of 17 Old 03-03-2019, 04:41 PM
evh
evh's Avatar
Likes (Given): 51
Likes (Received): 17
What ratio are you mixing the gas/oil? What you are showing is not totally unusual. I have worked on over 50 of there machines and typically there is oil in that area. Yours looks a little worse then what I have seen, however, you may be running too much oil.
I really would worry about it too much. Those engines are pretty hardy things. Again, how many ounces of 2-Cycle oil do your run to how many gallons of gas. It is a 50:1 ratio so that should be roughly 2.6oz per gallon of gas or 5.2oz per two gallons of gas.
You can also easily lift up the cover (remove 3 back screws and typically about 2 - 3 screws on each side and you can lift it and see the muffler and how much is leaking down the side of it. To remove the cover totally (vs just lifting it up), remove the top part of the chute and you can then slide the plastic cover totally off.
One thing I have learned is that living richly is less about the net worth on your bank statement and more about the value of the lessons you offer those who want to learn from you.
evh is offline
post #10 of 17 Old 03-03-2019, 05:16 PM Thread Starter
malisha1's Avatar
I have taken the covers off and most of the oil was a round the exhaust. I usually mix 25-30oz of gas just enough for one gas tank bc I don't get too much snow in NYC I don't want to store 2 cycle gas bc I have no other machines that need it.
Similar Threads
Honda Oil Leak Question orangputeh Honda Snowblowers 9 11-19-2018 08:25 AM
Lawn Boy 2 stroke crammit442 Lawn Boy Snowblowers 27 08-27-2017 05:11 PM
2 cycle 4 cycle performance 2 stroke 4 stroke snow2345ffs General Snowblower Discussion 26 12-24-2015 01:18 AM
Honda HS622 Transmission Leak Otto2015 Honda Snowblowers 2 04-19-2015 01:35 AM
New Piston and rings for two stroke. Pathfinder13 Snowblower Repairs and Maintenance Forum 42 03-10-2015 10:19 PM
