what to check when shopping for an old used engine? - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 03-08-2019, 06:17 PM Thread Starter
Question what to check when shopping for an old used engine?
I found a 12 HP Tecumseh Snowking engine from a local resident. He asked for $65. His word is "have not seen it run but he think it's good".
I was wondering what are few most important things to check when shop for an old used engine. I don't have a compression gauge. I saw some guy leave use 2 fingers to cover the empty spark plug hole and pull the starter cord to check and see if it got comprssion?
ksj0823 is offline
post #2 of 11 Old 03-08-2019, 06:35 PM
Thanks (Given): 166
Thanks (Received): 301
Likes (Given): 409
Likes (Received): 999
If the engine is complete you can put a plug it, some gas and start it on the ground. make sure it has oil At the very least you can squirt a shot of gas, starting fluid or carb and choke cleaner to make it fire.
micah68kj is offline
post #3 of 11 Old 03-08-2019, 07:29 PM
Thanks (Given): 87
Likes (Given): 86
Likes (Received): 6
Old engines that turn, can usually be freshened up to run strong. Corrosion from storage is always an issue . Points often corrode, and engine doesn't start . Figure on spending some money freshening up the magneto, than its done. Carbs are simple, and usually respond well to cleaning. Missing / broken parts are a hassle . The price sounds great .
Fat City is offline
post #4 of 11 Old 03-08-2019, 08:18 PM
Thanks (Given): 95
Thanks (Received): 191
Likes (Given): 73
Likes (Received): 435
You can check "some" compression by pulling the cord but that does not mean good compression. Best to spend $15 and buy a gauge, however it could have a rod knock and have good compression.
Agree with Micah, spray some starting fluid in the carb. You could even carry a snail gas tank with you and run the engine off of that but it may jump around. Sounds like this engine he got from somebody else.
post #5 of 11 Old 03-08-2019, 08:33 PM
Thanks (Given): 136
Thanks (Received): 300
Likes (Given): 400
Likes (Received): 723
Agreed that a compression tester is a good tool to have available. Can also be useful for engines you already own.
A spritz of starting fluid, carb cleaner, or gas, into the carb may show if it's willing to start.
If it fires for a few seconds, that's encouraging. Fuel issues can be cheaper and easier to resolve than ignition problems, for instance.
Good price, IMO, if you can get it running for cheap.
post #6 of 11 Old 03-08-2019, 08:56 PM Thread Starter
Thanks. I am still new to this. If rod crack down in there, should I hear some noise if I try to move the engine a bit?
ksj0823 is offline
post #7 of 11 Old 03-08-2019, 08:59 PM Thread Starter
Thanks, everyone. I learn something new on this forum everyday.
ksj0823 is offline
post #8 of 11 Old 03-08-2019, 09:21 PM
Thanks (Given): 95
Likes (Given): 73
A rod crack and rod knock are two different things. Rod crack is a crack in the connecting rod and that is never caught unless the engine is taken apart. A rod knock is a looseness caused by a worn bearing. You may be able to hear it if pulled with curd but that means it's really really bad otherwise a small knock can only be heard if running. You need the rpms to create the looseness.
post #9 of 11 Old 03-09-2019, 08:54 AM
Thanks (Given): 19
Thanks (Received): 48
Likes (Given): 107
Likes (Received): 220
You may get lucky 50/50 chance. The best scenario is it needs the carb cleaned. Worst scenario the engine wasn't stored right and the cyclinders, valves, are pitted and rusted.
On 4 cycle engines a major enemy is rust inside the cylinder. Always leave single cylinder engines on the compression stroke. This can be found as you pull on the engine’s starter cord; when the resistance is the most, you’re on the compression stroke. Leaving the engine this way closes the valves so atmospheric moisture cannot attack the cylinder walls.
russ01915 is offline
post #10 of 11 Old 03-09-2019, 03:40 PM
Jackmels's Avatar
Likes (Given): 448
Likes (Received): 789
Buy Something You can Hear Run. Otherwise, "It's like a Box of Chocolates"....
Jackmels is offline
Similar Threads
LCT Engine with Idle-Down Issues SnowH8ter Snowblower Repairs and Maintenance Forum 12 03-07-2019 12:52 AM
Direct replacement for Tecumseh LH195SP engine? chrispyny Re-Powering 12 01-05-2018 12:11 AM
kick back when starting AL- Snowblower Repairs and Maintenance Forum 46 04-09-2017 11:15 PM
1963 ariens engine swap mrjgc Re-Powering 22 09-29-2015 01:42 PM
need to know the maximum engine speed Markus (DE) MTD Snowblowers 2 02-09-2015 05:35 PM
