Before I Drill... Mounting bolts muffler Tecumseh 651002 - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 03-10-2019, 07:34 PM Thread Starter
Dannoman's Avatar
Thanks (Received): 18
Likes (Received): 119
I need to repair the threads for Mounting bolts muffler Tecumseh part # 651002
I have the bolts on order. But I will have to drill before I tap the hole and then install the inserts which are 5/16 size. My question is what is the proper drill size to use before I tap the hole? Is it 21/64? Thank you again for your help...
Dannoman is offline
post #2 of 4 Old 03-10-2019, 07:49 PM
Thanks (Given): 136
Thanks (Received): 304
Likes (Given): 400
Likes (Received): 723
Look like 21/64 for 5/16 Helicoil, if that's what you're doing:
https://www.mutualscrew.com/media/re...il%20chart.pdf
Thanks Dannoman thanked for this post
post #3 of 4 Old 03-10-2019, 07:50 PM
Cold1's Avatar
Thanks (Received): 8
Likes (Received): 10
Yep, if you're using helicoils, 21/64 is the correct size.
Ariens Deluxe 28 SHO
Touch Not A Catt Bot A Targe
Cold1 is offline
post #4 of 4 Old 03-10-2019, 08:10 PM Thread Starter
Dannoman's Avatar
Thank you gentlemen.
Dannoman is offline
Similar Threads
Tecumseh 8-10 hp muffler wire guard wanted part 127-20 FearlessFront Snowblowers and Snowblower Parts Wanted 9 01-21-2019 08:27 PM
Loose Muffler Tecumseh 8 horse Snapbean Ariens Snowblowers 9 02-25-2018 05:36 PM
Tecumseh - Muffler Bolts ts8169 Snowblower Repairs and Maintenance Forum 11 11-13-2017 09:43 AM
Removing Frozen Muffler Bolts Gonzo Ariens Snowblowers 7 08-22-2017 12:13 AM
Tecumseh Engine Electric Starter - stripped threads in mounting bolt holes CO Snow Snowblower Repairs and Maintenance Forum 12 12-24-2013 09:49 AM
