Trying to find year of my 1970s ariens sno thro - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 03-11-2019, 09:37 PM Thread Starter
Thekidmechanic05's Avatar
Likes (Received): 18
I want to know the year of my 70s sno thro but I can’t find where. I think it’s a 73 but I’m not sure. Model# 910995 serial# 109678. Thx guys.
Thekidmechanic05 is offline
post #2 of 13 Old 03-12-2019, 09:06 AM
Thanks (Given): 67
Thanks (Received): 381
Likes (Given): 172
Likes (Received): 871
910995 is the model number of the bucket attachment only, not the model number of the snowblower.
The model number of the snowblower will be at the rear of the machine, on another Ariens tag same as the one on the side of the bucket.
Also, if you can see a Tecumseh data tag on the side of the engine, post the numbers on that tag too..The Tecumseh serial number contains a date code.
post #3 of 13 Old 03-12-2019, 10:34 AM
Thanks (Given): 552
Thanks (Received): 722
Likes (Given): 4109
Likes (Received): 1579
The ID plate for your machine will look a little different but this is the place it should be. Might also be stamped into the metal.
The engine ID is on the top of the flywheel shroud and might be under the electric starter switch if yours is so equipped.
post #4 of 13 Old 03-12-2019, 06:22 PM Thread Starter
The tractor code is 910006. I can’t check the engine because it’s a predator 212
post #5 of 13 Old 03-12-2019, 07:09 PM
Thanks (Given): 67
Likes (Given): 172
Thats a 1972 or 1973 model 910006.
And in this case, its easy to tell which year!
If it has the two levers, (tractor and auger control levers) together on the side of the machine, like this:
Then it's a 1972.
If it has the "safety throw out clutch handle" (the tractor control lever) moved *behind* the handelbars like this:
Then its a 1973.
More info:
https://scotlawrence.github.io/ariens/Page5.html
Likes Grunt liked this post
post #6 of 13 Old 03-12-2019, 09:42 PM
AL-
AL-'s Avatar
Thanks (Given): 7
Likes (Received): 29
My 72 looks like this and the model no. is 910006. The tractor control lever is on handle bar. Engine serial n0. 2172D
Name:	ariens 72 .jpg
AL- is offline
post #7 of 13 Old 03-13-2019, 07:10 PM Thread Starter
Mine looks like that too
post #8 of 13 Old 03-13-2019, 08:25 PM
tlshawks's Avatar
Thanks (Given): 24
Thanks (Received): 41
Likes (Given): 44
Likes (Received): 231
Then they're 1973 model year tractors.
tlshawks is online now
post #9 of 13 Old 03-14-2019, 10:47 AM
AL-
AL-'s Avatar
Thanks (Given): 7
No - I have the original owners manual and parts manual in the parts manual it shows a diagram with the rod. Mine is missing the black plastic grip. The parts no. for the upper section of the rod is 10482. It shows the 910014,90006,91007,91008 & 910010 of that year all had the same setup and there was a 6,7,& 8 H.P.Tractor option.
AL- is offline
post #10 of 13 Old 03-14-2019, 12:46 PM
Thanks (Received): 199
Likes (Received): 725
My tractors with that set up are 910018 and 910019...the first one was 8 hp and chrome handles, the second was 7 hp and painted handles....
cranman is online now
Similar Threads
1970s Ariens Tear Drop Rutom Ariens Snowblowers 3 03-10-2019 01:22 PM
Do all vintage (1970's and earlier) Ariens crank the chute this quickly ? See Video. russkat Ariens Snowblowers 10 10-27-2016 06:05 PM
my 1963 ariens sno thro story: saved from near death mrjgc Ariens Snowblowers 22 09-25-2015 09:41 AM
1960 Ariens Sno Thro rnaude241 Snowblowers and Snowblower Parts Wanted 10 09-15-2015 10:57 PM
Ariens # 924020 Sno Thro UFCreel General Snowblower Discussion 4 11-08-2014 05:38 PM
