Predator 212 surging with new carburetor - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 03-26-2019, 10:04 PM Thread Starter
Thekidmechanic05's Avatar
Likes (Received): 18
The predator 212 on my ariens snowblower has been surging for quite some time. I drilled the jet, pilot jet and still have not fixed it. So I bought a new carburetor on eBay for 10 bucks. Thought for sure it would help. Ran great for the first few minutes of testing and then the surging started again. I’m stumped as to what Is going on.
Thekidmechanic05 is offline
post #2 of 7 Old 03-26-2019, 10:30 PM
Likes (Given): 213
Likes (Received): 304
Check the fuel tank vent mod discussed in this thread.
Skip to post number 80.
dbert is online now
post #3 of 7 Old 03-27-2019, 07:21 AM
Thanks (Given): 145
Thanks (Received): 324
Likes (Given): 429
Likes (Received): 775
Do you have an air leak around the carb? If you loosen/remove the gas cap while running, does that help?
post #4 of 7 Old 03-27-2019, 08:25 AM Thread Starter
I will try that today
post #5 of 7 Old 03-27-2019, 02:46 PM
orangputeh's Avatar
Thanks (Given): 747
Thanks (Received): 223
Likes (Given): 1506
Likes (Received): 1509
that's what i was thinking other than the gas cap. if you loosen gas cap and it does not surge then you know the problem.
did you change carb gaskets and/or make sure they were installed right without any passages in carb being blocked by gasket? also you can spray carb cleaner around gasket area while running and if engine changes then you know that is the problem. leak.
"It Feels Like Beer O'Clock "
orangputeh is online now
post #6 of 7 Old 03-27-2019, 03:46 PM Thread Starter
I’m going to try all of this
post #7 of 7 Old 03-27-2019, 05:43 PM
Thanks (Given): 78
Thanks (Received): 161
Likes (Given): 402
Likes (Received): 641
does partial choke smooth it out ? is there a steady stream of fuel to the carb ?
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
Similar Threads
Toro 518 ZR leaking fuel and surging madkiwi Toro Snowblowers 11 02-04-2019 09:31 PM
Carb problem, surging after ultra sonic, enlarge holes behind Welch? JLawrence08648 Snowblower Repairs and Maintenance Forum 19 01-24-2019 03:25 PM
storm 2410 Carburetor access issue gamechanger Troy-Bilt Snowblowers 16 01-20-2019 12:52 PM
Predator engine surging on my john deere snow blower Aypsears Re-Powering 20 03-05-2018 07:27 PM
Having Trouble Removing Carburetor from Snowblower Jack28 Snowblower Repairs and Maintenance Forum 28 08-21-2017 02:36 PM
