Pulled trigger on this - Snowblower Forum : Snow Blower Forums
post #1 of 18 Old 03-30-2019, 09:23 PM Thread Starter
Thanks (Given): 10
Thanks (Received): 17
Likes (Given): 31
Likes (Received): 31
I know the carbs are junk...which is the best after market carb for this...one with better materials so I dont fight the corrosion problem
Shovel is online now
post #2 of 18 Old 03-30-2019, 09:25 PM
Thanks (Given): 136
Thanks (Received): 304
Likes (Given): 400
Likes (Received): 723
Is it new? Replacing the carb on a new machine would seem odd to me, but I don't know anything about these carbs. My suggestion would be to try and find a carb with adjustable jets, if possible. Also a carb drain, ideally.
post #3 of 18 Old 03-30-2019, 09:28 PM Thread Starter
Thanks (Given): 10
Likes (Given): 31
It's new but I need to get a better carb for when the day happens ..I see em for 15 to 20 bucks...but dont dont which brand uses better materials
post #4 of 18 Old 03-30-2019, 09:29 PM
e.fisher26's Avatar
Thanks (Received): 47
Likes (Given): 43
Likes (Received): 59
Iíve bought 10 or more aftermarket amazon carbs, brand didnít matter to me, they all worked great. Use non-ethanol fuel when storing and stabil 360 adative to fight any corrosion.
Noma 10/29
Cub cadet 5/26 conv to 8/26
Toro 724 conv to 10/24
Husqvarna st230p
e.fisher26 is online now
post #5 of 18 Old 03-30-2019, 09:30 PM
Thanks (Received): 70
Likes (Given): 64
Likes (Received): 223
if it is brand new there is likely nothing wrong with the carb that is on it. if you got access to ethanol free fuel that would likely help keep it healthy along with running it out of fuel at the end of the season. if you got some 2 stroke equipment putting a bit of 2 stroke gas in it and then running it dry at the end of the season probably wouldn't hurt either.
yardworks 31AH6WKF515
crazzywolfie is online now
post #6 of 18 Old 03-30-2019, 09:30 PM
e.fisher26's Avatar
Likes (Given): 43
I donít think adjustable jets are available for these even aftermarket(that Iíve seen anyway)
Noma 10/29
Husqvarna st230p
post #7 of 18 Old 03-30-2019, 09:34 PM
Likes (Given): 64
i think i have read on here of people modifying old adjustable jets to work on new machines along with drilling out the main jet so it won't restrict things but never tried it myself. i think you got to re thread the adjustable jet to metric
post #8 of 18 Old 03-30-2019, 09:40 PM
e.fisher26's Avatar
Likes (Given): 43
Might work on tecumseh or Briggs but a powermore, i think they are too new for that
Noma 10/29
Husqvarna st230p
post #9 of 18 Old 03-30-2019, 09:50 PM
Likes (Given): 64
the carbs used on them are similar to the brigs and almost any other honda knock off design engine. the adjustable jets all work the same so it would not really be hard to make another one work similar.
https://superfastperformanceproducts...table-main-jet
post #10 of 18 Old 03-30-2019, 10:14 PM
orangputeh's Avatar
Thanks (Given): 726
Thanks (Received): 216
Likes (Given): 1378
Likes (Received): 1381
if you use ethanol free gas and/or a good gas stabilizer and drain at end of season where would corrosion come in?
"It Feels Like Beer O'Clock "
orangputeh is offline
Similar Threads
Just pulled the trigger Shatfieldj Ariens Snowblowers 2 12-29-2017 08:46 PM
oh man.. almost pulled the trigger Geno General Snowblower Discussion 6 08-30-2015 02:24 PM
Just pulled the trigger rfsdave Ariens Snowblowers 19 08-03-2015 11:14 PM
Pulled the trigger... A R I E N S micah68kj Ariens Snowblowers 30 12-25-2014 11:16 PM
pulled the trigger on unusual new ariens throttlejunkie450 Ariens Snowblowers 60 10-23-2014 01:31 PM
