First start of rider Mower...Uggggh!!!!! - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 16 Old 05-19-2019, 01:46 PM
Originally Posted by SimplicitySolid22 View Post
Has anyone tried to start their rider mower and the starter runs but the mower will not turn over.......you turn the key off and remove the key but the mower keeps trying to start and you can not stop the engine turning over?????? I run to get a wrench to loosen batt. cable and after 45 seconds to a minute....it turns itself off.
I let it cool down a couple of minutes I put the key back in and it started right up.....I do not know if I damaged it at all....it sounds different and seems to vibrate more but i am not sure if I am over reacting or?????
Any thoughts????? Should I just run it????
John Deere LT133.
Put new solenoid on it.
The starter itself may or may not be damaged.. if it still twirls fast enough.. then no need to worry about it.. the best way you can see if it's damaged is to just use it.
Shovel is offline
post #12 of 16 Old 05-19-2019, 04:11 PM
Thanks (Received): 147
Likes (Given): 52
Likes (Received): 514
The engine won't be damaged, just the starter ....
cranman is online now
post #13 of 16 Old 05-20-2019, 07:57 PM Thread Starter
SimplicitySolid22's Avatar
Thanks (Given): 51
Thanks (Received): 59
Likes (Given): 56
Likes (Received): 89
Thank You Cranman. Good to know...
SimplicitySolid22 is offline
post #14 of 16 Old 05-22-2019, 11:46 PM
ST1100A's Avatar
Thanks (Given): 10
Thanks (Received): 44
Likes (Given): 91
Likes (Received): 42
Yes that is the starter solenoid switch. They do go bad, that is common. They can "stick" and cause the problem you experienced, or they wont let any current through, and the starter motor will not spin at all.
ST1100A is offline
post #15 of 16 Old 05-28-2019, 08:37 PM Thread Starter
Thanks (Given): 51
Likes (Given): 56
Will order a new one....Thanks ST.
post #16 of 16 Old 05-29-2019, 01:22 AM
ST1100A's Avatar
Thanks (Given): 10
Likes (Given): 91
You are welcome.
If you did anything to the engine to make it not want to start, chances are, you just got the spark plug wet from unburned gasoline from it just spinning over and drawing the fuel mixture into the cylinder and not burning or igniting it.
If anything, the plug will become wet, or fouled. Then just clean the plug, dry it off and it should fire again.
About the only damage that might happen is overheating the starter motor. Eventually you could wear the brushes out prematurely, but chances are the starter motor will survive. Worst case, it would overheat and can burn out some of the windings in the armature, or just wear down the brushes before their normal time is up, or wear out the bearings/bushings in it, but most likely, everything will be fine, just check the spark plug if it doesn't want to start right away, the plug could be wet.
ST1100A is offline
Thanks SimplicitySolid22 thanked for this post
Likes SimplicitySolid22 liked this post
Similar Threads
what do these numbers mean??? stromr Honda Snowblowers 5 02-21-2019 08:40 PM
Craftsman small two cycle snowblower fails to start wmlaveck Snowblower Repairs and Maintenance Forum 25 02-25-2015 11:11 PM
Won't start - where do I start? DavidR Snowblower Repairs and Maintenance Forum 14 02-23-2015 07:28 AM
Nearly impossible to start, but runs fine. Coil? Glove Snowblower Repairs and Maintenance Forum 16 02-11-2015 10:06 PM
Electric start quit working. Spins but does nothing. Dorlow Snowblower Repairs and Maintenance Forum 8 02-10-2013 09:16 AM
