First start of rider Mower...Uggggh!!!!! - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 05-16-2019, 05:34 PM Thread Starter
SimplicitySolid22's Avatar
Thanks (Received): 77
Likes (Given): 74
Likes (Received): 121
Has anyone tried to start their rider mower and the starter runs but the mower will not turn over.......you turn the key off and remove the key but the mower keeps trying to start and you can not stop the engine turning over?????? I run to get a wrench to loosen batt. cable and after 45 seconds to a minute....it turns itself off.
I let it cool down a couple of minutes I put the key back in and it started right up.....I do not know if I damaged it at all....it sounds different and seems to vibrate more but i am not sure if I am over reacting or?????
Any thoughts????? Should I just run it????
John Deere LT133.
SimplicitySolid22 is offline
post #2 of 16 Old 05-16-2019, 08:02 PM
e.fisher26's Avatar
Thanks (Received): 47
Likes (Given): 43
Likes (Received): 59
Sounds like ignition got stuck
e.fisher26 is online now
post #3 of 16 Old 05-16-2019, 08:23 PM
Thanks (Given): 27
Thanks (Received): 21
Likes (Given): 116
Likes (Received): 40
I have had my 69 Cab Cadet crank over if the regulator coil is picked by hand???
contender is offline
post #4 of 16 Old 05-16-2019, 08:38 PM
e.fisher26's Avatar
Likes (Given): 43
Also the if the starter was turning but not the motor, the gear on the starter needs some WD-40.
post #5 of 16 Old 05-17-2019, 09:30 PM Thread Starter
Likes (Given): 74
Motor was turning just would not start ...flywheel was spinning pretty quick.....
That is what it was like...the ignition got stuck.....when i turned it off the motor/Starter kept spinning and I removed the key.....was rather frustrating. I punched the coil.....nothing....thought it was frozen..
I turned the throttle down which also did nothing...
Hope no damage as a result....
13hp Kohler....has been solid for 14 years....Well maintained.
post #6 of 16 Old 05-18-2019, 02:33 AM
ST1100A's Avatar
Thanks (Given): 134
Thanks (Received): 115
Likes (Given): 245
Likes (Received): 197
Your starter solenoid switch contacts were stuck together. Sometimes they "Burn" together, I.E. "Weld" together, and stick. Sometimes the magnetic piston that moves inside the solenoid switch housing sticks.
Usually just tapping it with something will "Un-stick" it, but not always.
That is a common occurrence sometimes, you may have to replace the starter solenoid switch at some time, either now, or in the future. I see that problem happen a lot of times. It is scary when it happens, you don't want to burn out the starter motor or have the battery go dead, or have a fire from the heat created when it happens.
ST1100A is offline
post #7 of 16 Old 05-18-2019, 12:12 PM
Thanks (Received): 202
Likes (Received): 738
I second the notion that the solenoid is bad....replace.......
cranman is online now
post #8 of 16 Old 05-19-2019, 02:08 PM Thread Starter
Likes (Given): 74
Thank You ST ,Cranman and ef26 ...I appreciate all of your help. That is what I thought I tried to hit it but.....
Do you think engine cranking without starting would have harmed motor at all or just the starter solenoid took the brunt???
post #9 of 16 Old 05-19-2019, 02:19 PM Thread Starter
Likes (Given): 74
Is this the part you mean:
post #10 of 16 Old 05-19-2019, 02:19 PM Thread Starter
Likes (Given): 74
Cran is this the part you and ST mean:
Similar Threads
what do these numbers mean??? stromr Honda Snowblowers 5 02-21-2019 09:40 PM
Craftsman small two cycle snowblower fails to start wmlaveck Snowblower Repairs and Maintenance Forum 25 02-26-2015 12:11 AM
Won't start - where do I start? DavidR Snowblower Repairs and Maintenance Forum 14 02-23-2015 08:28 AM
Nearly impossible to start, but runs fine. Coil? Glove Snowblower Repairs and Maintenance Forum 16 02-11-2015 11:06 PM
Electric start quit working. Spins but does nothing. Dorlow Snowblower Repairs and Maintenance Forum 8 02-10-2013 10:16 AM
