Snowblower "Tune-Up" - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 08-14-2019, 10:01 AM Thread Starter
Question Snowblower "Tune-Up"
If you took your snow blower into a shop for a tune-up/pre-winter check over, what would you expect to have done?
Rickster55 is offline
post #2 of 11 Old 08-14-2019, 10:11 AM
e.fisher26's Avatar
Thanks (Received): 47
Likes (Given): 43
Likes (Received): 61
Spark plug, oil change, grease fittings, belt check/replace. Skid shoes/scraper adjustment/replacement.
e.fisher26 is online now
post #3 of 11 Old 08-14-2019, 11:52 AM
leonz's Avatar
Thanks (Received): 90
Likes (Given): 76
Likes (Received): 172
Add a compression test if its older and checking the drive tire if it's not a snow mule with a hydrostatic transmission.
The other thing up in the air is the condition of the tires and if the side walls have deteriorated they will have started to separate where the outer covering has started to separate from the sidewall layers and the rubber will look like pie wedges with old rubber.
When they look like this you need to decide whether you want to have tubes stuffed in them or just replace them. Replacing them will be less costly as the tires are weaker from age and exposure to ozone.
This takes 8 or more years to occur so you have to decide whether to have them changed.
The other thing is a tire store will be able to do this for you much more quickly and be less costly as they have the small tire jig tools to do this where a lawn mower shop will not have them.
In most cases and they may go all Samsonite gorilla suit case tester on them to remove the old rubber tires as they never ever use graphite tire lubricant to mount them and the rubber glues itself to the rims and they need to spend a lot of time cleaning the beads to have a proper bead seal to hold air.
If you have bad tires taking them or the entire snow mule to a tire shop will get them done more quickly, BUT the time
required remove them from the axle shafts is another issue as they can be stubborn as antisieze compounds are not brushed on these axle shafts anyway.
If they are old its better to do the tires now than have them fail in a 200 year snow storm.
leonz is online now
post #4 of 11 Old 08-24-2019, 08:35 PM
Thanks (Given): 95
Thanks (Received): 192
Likes (Given): 73
Likes (Received): 436
Expect the repair shops to do, Want them to do, and What they do, Are all different things
JLawrence08648 is offline
post #5 of 11 Old 08-25-2019, 08:21 AM
orangputeh's Avatar
Thanks (Given): 727
Thanks (Received): 216
Likes (Given): 1389
Likes (Received): 1388
one thing i have learned in 60 plus years
if you want it done right.........do it yourself
"It Feels Like Beer O'Clock "
orangputeh is online now
Likes Grunt, evh, rod330 liked this post
post #6 of 11 Old 09-07-2019, 04:58 PM
Thanks (Given): 245
Thanks (Received): 11
Likes (Given): 68
Likes (Received): 52
How long does it usually take before you should consider changing a spark plug after buying a new machine?
barney is offline
post #7 of 11 Old 09-07-2019, 05:41 PM
Thanks (Received): 91
Likes (Given): 38
Likes (Received): 238
Spark plugs are cheap, so at least have a spare on hand. Change it when the engine is running crappy. Cheap and easy so it should be the go-to repair.
RIT333 is online now
Thanks barney thanked for this post
post #8 of 11 Old 09-07-2019, 05:52 PM
Thanks (Given): 245
Likes (Given): 68
Generally speaking, and out of curiosity how many seasons do plugs last? 2 years? 8 years?
barney is offline
post #9 of 11 Old 09-07-2019, 07:22 PM
WVguy's Avatar
Thanks (Received): 40
Likes (Received): 158
Generally replacing spark plugs go by hours of use, that should be in the owner's manual, but between 50 and 100 hours would be a guide for one that is used very often, as in commercially. More practically speaking, since they are so cheap and easy to replace as RIT333 said, they are one of the first things to check when the engine starts getting fussy.
That said, in my experience I've just once in my life (at age 69) seen a small engine spark plug go bad. Wear out, yes, but just up and stop working, no.
WVguy is offline
post #10 of 11 Old 09-07-2019, 10:15 PM
tabora's Avatar
Thanks (Given): 42
Thanks (Received): 201
Likes (Given): 120
Likes (Received): 395
I never actually needed to change the spark plug on my 1986 Honda snowblower or my 1982 Honda mower. I've checked them every few years, but they still work just fine.
tabora is online now
