Is John Deere 827e blower any good? - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 08-26-2019, 04:00 PM Thread Starter
Hi folks I recently came across a John Deere 827e used for 700, was debating on pulling the trigger, I’m currently working with a 1977 Canadiana 8/26 converted to a 10hp Tecumseh off yardworks, should I stick with what I got? Don’t know much about the Deere’s other then price of parts I hear is bad. I’m mainly looking for reliability and not having to wrench as much
Frankenblower is offline
post #2 of 15 Old 08-26-2019, 04:04 PM Thread Starter
Here’s pics
ID:	156741   Click image for larger version
post #3 of 15 Old 08-26-2019, 09:03 PM
Thanks (Received): 140
Likes (Given): 204
Likes (Received): 292
That looks to me like it may be one of the JD's built by Ariens.
dbert is offline
post #4 of 15 Old 08-26-2019, 10:12 PM Thread Starter
That’s what it use to look like
post #5 of 15 Old 08-27-2019, 08:04 AM
tdipaul's Avatar
Thanks (Given): 78
Thanks (Received): 81
Likes (Given): 315
Likes (Received): 342
Based on the control panel and control lever design it looks like it was made by Simplicity/Briggs. Good machines. I'd offer $500 cause its August and I see some rust spots on the bucket. Check the impeller blades!
1989 John Deere 1032
tdipaul is online now
post #6 of 15 Old 08-27-2019, 04:41 PM Thread Starter
Looks like the blower sold, I may ride this winter out unless something else comes up, I like mine but kinda want something newer, driveway is big in width takes me about an hour with the 24” not sure if bigger is nessarily better
post #7 of 15 Old 08-27-2019, 05:39 PM
tabora's Avatar
Thanks (Given): 42
Thanks (Received): 199
Likes (Given): 120
Likes (Received): 391
Originally Posted by Frankenblower View Post
...driveway is big in width takes me about an hour with the 24” not sure if bigger is nessarily better
I went from a 24" Honda HS80 to a 32" HSS1332 and the time required to do my driveway & walks was cut in half.
tabora is online now
post #8 of 15 Old 08-27-2019, 06:38 PM Thread Starter
Much difference in the sense of machine size do you fight with it a bit more in 30”?, never ran one bigger then 24”
post #9 of 15 Old 08-27-2019, 09:41 PM
tabora's Avatar
Thanks (Given): 42
Likes (Given): 120
Much difference in the sense of machine size do you fight with it a bit more in 30?, never ran one bigger then 24
There's no fighting with the Honda HSS1332ATD... Just walk along behind and enjoy the process. The steering controls and left thumb auger height adjustment make it a whole new experience compared to small 24" 2-stage blowers I've used previously. My guess is that the 30" Husqvarna ST 430T or 32" Ariens Professional Rapidtrak would be in the same league.
post #10 of 15 Old 09-02-2019, 05:49 PM Thread Starter
New blower or continue fixing
So another hiccup discovered impeller shaft has worn down shaft, I’ve jb welded the 1/16 gap, have my doubts on it but gunna try it see how far it gets me, if not I’m looking at ariens, husqvarna or yardworks brand new what do you guys recommend for reasonable price blower, not looking for anything fancy 24-30”
