Help me ID this tank! - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 08-29-2019, 09:57 PM Thread Starter
I recently purchased this tank from facebook marketplace for $60
I am pretty good with small engines and have the necessary tools to repair / maintain them.
Few years ago I got a 1995 toro 7Hp, 24" snowblower, tuned it up, and it runs better and throws snow better than my neighbors $1000 snowblower.
Anyway, this 10Hp, 32" beast is labeled JC Penney. From what I found online, seems to be a rebranded MTD.
https://www.toolpartsdirect.com/mtd-...del-4924a.html
Unfortunately, that web page doesn't have parts or part numbers.
The carb leaked from the float bowl. I tried to repair it , but the gaskets are shot and need to be replaced.
The chute control cable was seized up and rusted, so I found a Murray cable, identical to my cable, even with adjustable ends. $20 on ebay.
It starts, runs, the augers spin, and seems to be a solid machine.
I noticed on the right wheel... it is a bit wobbly. Where it slides onto the axle, near the center, by the gearbox, it seems as if a spacer or bearing was there to keep the axle straight and not wobble. Without an ID, I can not find a parts breakdown for this machine
So far in $80 into this machine.
I need help with identifying the machine and engine. I know the engine is a Tecumseh 10Hp, but without the year, I can not find too much on it.
I attached some pics.. any info would be greatly appreciated
Antonio Brunello is offline
post #2 of 4 Old 08-30-2019, 01:02 AM
tabora's Avatar
Thanks (Given): 42
Thanks (Received): 203
Likes (Given): 121
Likes (Received): 396
Yup, rebranded pre-1990 (likely 1988) MTD 4924A: http://www.m-and-d.com/pdfs/MTD/4924A.pdf
Service manual: https://www.repairmanual.com/product...-manual-ssm-3/
Look under the engine cover for the engine ID label.
tabora is offline
post #3 of 4 Old 08-30-2019, 09:39 AM Thread Starter
Hello!
Thanks for the quick reply
I had to do some cleaning and rubbing, but I found the engine model HM100-159117n.
purchased new carb gasket today ( gotta love amazon)
I removed the pin from the right wheel , but it will not come off the axle, yet.
Some PB blaster, maybe some heat and lots of elbow grease should fix that problem.
thanks again
I will post more pics as I work on the unit
Likes Zavie liked this post
post #4 of 4 Old 08-30-2019, 02:27 PM
tabora's Avatar
Thanks (Given): 42
Likes (Given): 121
That's great! Here's a link to the exploded parts diagrams/lists: http://www.barrettsmallengine.com/te...00-159117N.pdf
Here's the Tech Manual: https://www.manualslib.com/manual/10...?page=1#manual
tabora is offline
