Help me make my final choice - Snowblower Forum : Snow Blower Forums
View Poll Results: Pick the machine I should buy
toro 928 1 6.25%
toro 1028 4 25.00%
ariens deluxe 28 sho 10 62.50%
ariens deluxe 30 1 6.25%
Voters: 16. You may not vote on this poll
post #1 of 17 Old 10-14-2019, 07:42 PM Thread Starter
after all my research I decided to by ariens or toro. I have it narrowed down to four models. The ariens deluxe 28" SHO or deluxe 30" and toro the 928 or 1028. I have a large pad that can park over six cars and it has a incline out and its about 200 feet. Both will be coming from a local dealer.
compassman is online now
post #2 of 17 Old 10-14-2019, 07:50 PM
1132le's Avatar
Thanks (Given): 28
Thanks (Received): 83
Likes (Given): 60
Likes (Received): 189
28 sho
1132le is online now
post #3 of 17 Old 10-14-2019, 08:09 PM
orangputeh's Avatar
Thanks (Given): 668
Thanks (Received): 176
Likes (Given): 1063
Likes (Received): 1096
none of the above.
anyway cannot help unless you say how much snow you get, wet/dry, budget , elevation, and other variables.
otherwise pick out of a hat.
"It Feels Like Beer O'Clock "
orangputeh is online now
Likes uberT, The Q liked this post
post #4 of 17 Old 10-14-2019, 08:17 PM
oneacer's Avatar
Thanks (Received): 39
Likes (Received): 115
They sell Ford, Chevys, and Chrysler, etc .... When it comes down to it, the final decision is yours.
You will get the Ariens camp telling you Ariens, and the Toro camp telling you Toro. Me, I am an Ariens guy, as I have never been a fan of Toro, as my neighbor had a Toro mower, a peice of junk, always breaking down. But that was years ago, and not a snowblower ... I am sure either one will suit you.
oneacer is online now
post #5 of 17 Old 10-14-2019, 08:29 PM
Zavie's Avatar
Thanks (Given): 51
Thanks (Received): 87
Likes (Given): 382
Likes (Received): 173
I'd probably go with the SHO. I don't care for the Toro quick stick that much. Everytime you move the chute, the chute deflector's setting has to be reset. On a windy day no matter the chute setting I'm more apt to leave the deflector set. If you must go Toro then I'd choose the 1028 because of the handwarmers that the 928 does not have. I own both brands and both are very good machines.
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is online now
post #6 of 17 Old 10-14-2019, 09:27 PM
Thanks (Given): 8
Likes (Given): 7
Likes (Received): 14
Toro 1028 is my vote.
Sent from my SM-N975U using Tapatalk
robs9 is online now
post #7 of 17 Old 10-14-2019, 11:26 PM
enigma-2's Avatar
Thanks (Received): 18
Both are good machines, I currently own a Toro (smaller, older) and an Ariens (24 platinum).
If you haven't already, visit both dealers and go hands on. Try the controls, compare the overall feel.
I got curious myself and ran a quick comparison on the two lower versions. Here's my results:
Ariens Deluxe 28 SHO
306cc Engine: 306cc
Fuel tank: 0.8 gal
Torque: 17 ft-lb
Auger dia: 14"
Impeller dia: 14"
Auger: serrated
Chute: steel
Chute rotation: 200 deg
Max throwing distance: 55 ft
Steering: auto turn
Gear case: cast iron
Reverse: 2 speeds
Forward: 6 speeds
Tires: 16 x 4.8"
Remote deflector controls: both
Interlocking controls: yes
Hand warmers: yes
Headlight: halogen 20 watt
Weight: 286 lbs
Warranty: 3 years
Length: 58.3", width: 26.4", height: 45.9"
Toro Power Max HD 928 OAE
Engine: 265cc
Fuel tank: 0.9 gal
Torque: n/a
Auger dia: 14"
Impeller dia: 12"
Auger: serrated
Chute: steel
Max throwing distance: 45 ft
Steering: auto turn
Gear case: aluminum
Reverse: 2 speeds
Forward: 6 speeds
Tires: 16 x 4.8"
Hand warmers: no
Headlight: LED
Weight: 264 lbs
Warranty: 3 years
Length: 63", width: 29", height: 44.5"
The Ariens has a more powerful engine and throws more snow, further. Its heavier and smaller than the Toro. And it has hand warmers. Augers are the same size, the impeller is 2" larger on the Ariens.
The Ariens uses shear pins to fault, the Toro claims its it's hardened gears can withstand any jam without shear pins. (Its engine just stops dead, not convinced this is all that good for an engine).
Speaking as an Ariens owner, I would buy again. Best machine I've ever owned. And it outsells all other brands. The Toro still runs great (my backup machine), but it's made of less expensive materials. (In all fairness however, I haven't looked at the 928 other than online).
2014 Ariens 24" Platinum
Toro CCR 3650 GTS
enigma-2 is offline
post #8 of 17 Old 10-14-2019, 11:55 PM
1132le's Avatar
Thanks (Given): 28
Likes (Given): 60
306cc Engine: 306cc
Fuel tank: 0.8 gal
Torque: 17 ft-lb
Auger dia: 14"
Impeller dia: 14"
Auger: serrated
Chute: steel
Steering: auto turn
Reverse: 2 speeds
Forward: 6 speeds
Tires: 16 x 4.8"
Hand warmers: yes
Weight: 286 lbs
Warranty: 3 years
Engine: 265cc
Fuel tank: 0.9 gal
Torque: n/a
Auger dia: 14"
Impeller dia: 12"
Auger: serrated
Chute: steel
Steering: auto turn
Gear case: aluminum
Reverse: 2 speeds
Forward: 6 speeds
Tires: 16 x 4.8"
Hand warmers: no
Headlight: LED
Weight: 264 lbs
Warranty: 3 years
Which is why i said 28 sho
bigger motor
bigger impeller
blows snow better
heated grips
better value for the money
not and ariens homer
its just better
post #9 of 17 Old 10-15-2019, 12:02 PM
Likes (Received): 8
TooTall999 is online now
post #10 of 17 Old 10-17-2019, 07:51 AM
69ariens's Avatar
Thanks (Received): 38
Likes (Given): 53
Likes (Received): 100
As you can see the the video above. The Toro has no problem in deep snow and the chute control are the best. As for the engine size, With Toro's design , it doesn't require a larger engine like other brands.
Scott
69 ariens
toro 721r
toro 926 hd oxe
69ariens is offline
