420cc Briggs & Stratton Vs LCT? => Help Me Decide - Snowblower Forum : Snow Blower Forums
post #1 of 34 Old 11-07-2019, 05:49 PM Thread Starter
Thanks (Given): 9
Likes (Received): 18
Hi,
I was just notified by my Ariens dealer that I could get the snowblower I ordered with either the Briggs & Stratton engine or the LCT engine. Originally I was told that they only had access to the LCT engine version, so this means now I have to decide. This is the 420cc carbureted engine (wanted EFI, but not available with Ariens FasTrak :-().
After searching around on the web, it's hard to tell if one is better than the other. Most of the experts (Paul Sikkema and others) don't seem to have a strong preference either way. Maybe that's a good thing and means that they're both OK. But I'm obsessing over this and hoping you guys can chime-in and help tip the scales for me one way or the other.
Any feedback appreciated!
Regards,
Eric
ericr is offline
post #2 of 34 Old 11-07-2019, 05:53 PM
Thanks (Given): 63
Thanks (Received): 79
Likes (Given): 77
Likes (Received): 127
Is the LCT a 420 Also???? I assume you meant both but...want to be sure.
SimplicitySolid22 is offline
post #3 of 34 Old 11-07-2019, 05:55 PM
Thanks (Given): 63
Likes (Given): 77
Or LCt 414CC?
Likes ericr liked this post
post #4 of 34 Old 11-07-2019, 05:56 PM
Thanks (Received): 26
Likes (Received): 85
From what I know, both are good engines mechanically. I've got a Briggs 420 personally and it's been a good unit so far. The Briggs does have the advantage of a much larger fuel tank (about 1.5 gallons) and there's also a 12v starter, etc. available for this engine, so battery start conversion is fairly easy if desired.
rslifkin is offline
post #5 of 34 Old 11-07-2019, 06:09 PM Thread Starter
Thanks (Given): 9
Yes, both 420cc.
ericr is offline
post #6 of 34 Old 11-07-2019, 06:14 PM
Thanks (Given): 63
Likes (Given): 77
Briggs Gross Torque 21 ft. lbs.
LCT Gross Torque 20 ft. lbs.
Briggs 1.5 gallon Tank
LCT 1 Gallon Tank
Briggs weighs 81LBS.
LCT weighs75.5LBS.
post #7 of 34 Old 11-07-2019, 06:28 PM Thread Starter
Thanks (Given): 9
Here's what I found on power:
B&S
Torque curve: http://bsintek.basco.com/BriggsDocum...DvrS8lFix2.pdf (re-edited to fix this)
The max HP is at 3600 RPM. The torque at that RPM looks like about 19.8 ft lbs, so a quick HP calculation gives 13.6 HP
LCT
Couldn't find a torque curve.
But see page 3 of: https://redlionproducts.com/media/42...evd_101413.pdf
They quote 13.0 HP
So if you believe all that the B&S is slightly more powerful.
ericr is offline
post #8 of 34 Old 11-08-2019, 09:55 AM
Thanks (Received): 8
Likes (Received): 27
Go with the Briggs. The EFI, LCT version has a half gallon tank which leads to a short run time of about 45 minutes. The carburetor version of the Briggs has a larger tank as I recall.
Robert
bbwb is offline
post #9 of 34 Old 11-08-2019, 10:53 AM Thread Starter
Thanks (Given): 9
Robert
There is no EFI LCT version offered. The only LCT option I have is the non-EFI version.
Do you know what the gas tank size is on the non-EFI LCT engine?
I still don't feel like there's much to differentiate between the two options.
I understand that Ariens is getting away from B&S. I heard that the reason is simply because B&S now owns a bunch of other snowblower brands, which makes them a competitor to Ariens.
ericr is offline
post #10 of 34 Old 11-08-2019, 11:54 AM
Thanks (Given): 71
Thanks (Received): 118
Likes (Given): 571
Likes (Received): 270
I know the throttle's are different on both. I prefer the Briggs throttle because it has a wide range and is easily adjusted. Some on the forum have mentioned that the LCT throttle is just idle or full. I don't know if this is the case on the LCT 420cc but you might check if this makes a difference to you.
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is offline
