Predator 420 headlight wiring - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 11-30-2019, 08:11 PM Thread Starter
Likes (Received): 17
Hey guys, how do i hookup a light on my Predator 420cc? I canít seem to find any info on this. I have a hella 70 light i want to use, if possible.
HELLA 996176491 Module 70 Series 12V/55W Close Range Halogen Work Lamp
2015 Ariens Platinum SHO 24" AX369 | 1995 Troy-Bilt 8/24 w/ Predator 420cc
PB617 is offline
post #2 of 8 Old 11-30-2019, 08:24 PM
Thanks (Received): 52
Likes (Given): 44
Likes (Received): 71
I donít believe you can, might need a small power equipment battery a couple LED lights and a switch.
e.fisher26 is online now
post #3 of 8 Old 11-30-2019, 08:26 PM
Likes (Given): 28
Likes (Received): 41
The Predator doesn't have the stator needed to generate power for a headlight. That's why you can't find any information on it.
TooTall999 is offline
post #4 of 8 Old 11-30-2019, 08:32 PM Thread Starter
Ah, that makes sense. Thanks!
PB617 is offline
post #5 of 8 Old 12-01-2019, 08:42 PM
Likes (Received): 40
The Predator 420 used to have 12v output, pretty sure it still does when it has 12v starting.
Google around and it should take you back to this forum where someone mentions 12vdc out at the starter solenoid stud?
https://www.snowblowerforum.com/foru...ternators.html
bigredmf is offline
post #6 of 8 Old 12-01-2019, 09:43 PM Thread Starter
I actually saw that thread when i was digging around. Mine does have a 12v starter solenoid. I tried hooking up the light but i didnít get it to work. I have to check again.
PB617 is offline
post #7 of 8 Old 12-02-2019, 07:27 PM
Likes (Given): 14
Likes (Received): 25
I put a 420 HF unit on my 32" Craftsman Driftbreaker. I put a small PWC battery on it and am able to have any 12v lights and electric start. I put on LED Lights. You can also adjust the high speed up a couple of hundred RPM's with adjustment. The engine is quite and has a ton of power.
Read through my post. I also put on a electric chute rotator and heated grips.
https://www.snowblowerforum.com/foru...eneration.html
sock-feet is offline
post #8 of 8 Old 12-03-2019, 09:54 AM Thread Starter
Originally i was planning on getting a battery. I figured i would keep it simple but key start would be nice! I might just do that. I got to briefly try out the 420 yesterday. Its a beast for sure, especially on a 24Ē bucket. I have a build thread also-
Troy-Bilt 8/24 re-power https://www.snowblowerforum.com/foru...d.php?t=148793
PB617 is offline
