Looking at JD 1032 - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 12-02-2019, 12:17 AM Thread Starter
Looking at JD 1032
Hi all thanks for being here and for your experience .
Im looking at a olsed John Deer 1032. They said they dont know how old it is, but say it runs very well. I was told it was a 15 H P engine.
So my questions to you all are, is this known as a good machine ? Is there anything i should look at when i go see it ?
There asking 300.00 Canadian , seems like a fair price .
Thanks in advance for your help
Ramone
ramone1961 is offline
post #2 of 16 Old 12-02-2019, 07:56 AM
Pics?
Frankenblower is offline
post #3 of 16 Old 12-02-2019, 08:33 AM
Thanks (Received): 15
Likes (Received): 46
Unless they have changed the engine it should be 10 hp, 32" cut, that is what the model designation refers to. Whether or not it is a "good" machine depends on who built it and when. Older JD built machines are pretty decent, newer outsourced JD machines are not so great. It is pretty cheap though if it works well.
Ariens 1027le
Meyer 8' Stainless Lot Pro fitted to 2012 F250
17 Arctic Cat Mtn Cat, for the day after
Brent Holm is offline
post #4 of 16 Old 12-02-2019, 08:59 AM
Thanks (Received): 82
Likes (Given): 76
Likes (Received): 287
really hard to say if it is a good deal or not without pics. i have seen people selling off big machines like that that they say all works good but you can clearly see issues with.
yardworks 31AH6WKF515
crazzywolfie is online now
post #5 of 16 Old 12-02-2019, 07:33 PM Thread Starter
Thanks so much all. here are some pics /Users/rayaubie/Desktop/Pics/IMG_1182.jpeg/Users/rayaubie/Desktop/Pics/IMG_1181.jpeg
Pics below
Thanks so very much
Any thoughts wit the pics
Ramone
ID:	160173   Click image for larger version
ID:	160175   Click image for larger version
post #6 of 16 Old 12-02-2019, 07:49 PM
Thanks (Received): 99
Likes (Given): 68
Likes (Received): 223
Those 358cc tecs like all engines were over rated its 9 hp on its best day has 15 lb ft of torq
its worth 300 in nice shape
1132le is offline
post #7 of 16 Old 12-02-2019, 07:49 PM
Thanks (Received): 152
Likes (Received): 548
Right off the bat, needs some new tires instead of those turf tires, also you can tell its been stored outside.
To be honest, I have got better machines for free in my area, but I am not in Canada … I have no idea as to its condition, but I would imagine its going to need some parts and time just to get it in operating condition, let alone it will take a bit of work/time to get it looking good as well.
JMHO
oneacer is online now
post #8 of 16 Old 12-02-2019, 07:51 PM
Thanks (Given): 97
Likes (Given): 76
Likes (Received): 463
There are many of us on here with the same machine. This machine was made in the late 70s & early 80s. It is one of only a few machines of real quality, aka, cast iron gear box, super thick auger, 16" auger, 12" impeller, not another snowblower has an impeller this thick! None! It's a 10hp Tecumseh. The down side to this machine are several. The chute is too short and needs to be cut and lengthen otherwise it doesn't throw snow very far, not far at all!!! The handlebars are weak and the metal will crack. It needs to be better supported as the machine is so heavy. The squeeze handle to propel the snowblower is on the bottom forcing you to squeeze it rather than holding it down, it's very tiring. Where are the chains? That model comes with chains though you do not need them.
JLawrence08648 is offline
post #9 of 16 Old 12-02-2019, 08:47 PM
Likes (Given): 76
really hard to say. almost looks like the back of the lower bucket at the back may be patched up. would definitely want to look at that better especially since 1 skid is wore down to nothing and the other is missing.
post #10 of 16 Old 12-03-2019, 07:54 AM
Likes (Received): 17
If it were in my area, I would pass on it. Looks nice for a summer project.
The Q is offline
