Ariens 28 Pro compared to Toro 1428 - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 12-03-2019, 06:58 PM Thread Starter
Thanks (Given): 21
Thanks (Received): 17
Likes (Given): 96
Likes (Received): 81
OK guys, no matter what the replies are, I am a year too late to follow suggestions BUT I am curious. Specifically to steering. My 28 Pro, not the hydro machine purchased late last season so far does well with snow. I read where Ariens moved the wheels toward the machine’s front to help their steering making it too light on the front. And yes, prior to using mine much, I noticed how it would climb when I hit snow bank.
Ariens must have noticed the wheel location change created a problem so how did they fix that? They added two holes into the augur enclosure to accommodate a new weight bar they peddle rather than improve the machine’s turning problem. I did add a 25# SS bar to the augur enclosure.......that did bother me!
I don’t really have a major bitch about Arien’s turning design other than to point out turning problems were solved decades ago by manufacturers by using a differential. And yeah, I admit even those had engineering problems’s. My old Bolens used that design making turns very very easy.
Those differentials were used by at least two manufacturers. The shortcomings I found were first, it needed shaft seals to keep water out of it. Should also have had grease zerk fittings and finally in the designer’s attempt to make it satisfy all users, the wheels could be locked together. That fix sucked by creating a weak axle that could snap. I know! Mine did.
Now back to Toro which I know zero about other than they advertise POWER STEERING! So guys, what is Toro’s power steering? And while at it, how does it compare to Ariens mediocre steering solution?
foggysail is offline
post #2 of 4 Old 12-03-2019, 07:18 PM
Thanks (Given): 71
Thanks (Received): 118
Likes (Given): 571
Likes (Received): 270
The Toro has triggers on each handle. Pull on the trigger and that allows you to turn in that direction. Many makers offer a similar system. I'm not sure why it's called power steering? Maybe other names were taken.
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is offline
post #3 of 4 Old 12-03-2019, 07:23 PM
Thanks (Given): 71
Likes (Given): 571
Here is a recent thread where the two are discussed:https://www.snowblowerforum.com/foru...uto-steer.html
Zavie is offline
post #4 of 4 Old 12-03-2019, 08:02 PM Thread Starter
Thanks (Given): 21
Likes (Given): 96
Thanks guys!!!
