gallop - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 12-11-2019, 05:42 AM Thread Starter
gallop
Have a blower with a Tecumseh engine that is "galloping" and don't know how to fix it. Gallop=constant rpm up and down. Does anyone know the fix for this problem? thank you, gregjo1948
gregjo1948 is offline
post #2 of 9 Old 12-11-2019, 07:33 AM
Thanks (Given): 97
Likes (Given): 76
Likes (Received): 463
It's called surging. Carb. Low mixture circuit. Clean it well or put on a new Chinese carb. Cleaning it well means removing the Welch plug on the side, spraying carb cleaner in the holes, using a welding torch cleaner to clean the holes. Take pics before you take it off. Notice the holes for the linkage.
post #3 of 9 Old 12-11-2019, 07:40 AM Thread Starter
I've had it off and cleaned it but, didn't remove the plug. I'll do it again and remove the plug. Can I reuse the plug? thanks, gregjo1948
post #4 of 9 Old 12-11-2019, 07:47 AM
Thanks (Given): 97
Likes (Given): 76
Behind the plug is where the problem is. You have to drill it out then pry so it's not reusable. I buy a dozen at a time for $1 each. Cheaper in a kit from Amazon than at the parts store. A mower repair store may have extras in a bag. Check there. After installed with a hammer and punch, you need to spread it out to seal, you then do a complete seal with nail polish along the edge. A welder's tip cleaner is $2-$3.
post #5 of 9 Old 12-11-2019, 07:51 AM Thread Starter
I have tip cleaner but a little low on nail polish.
post #6 of 9 Old 12-12-2019, 03:54 PM
Thanks (Given): 7
Likes (Received): 9
I'd 2nd the idea of just replacing the carb with a cheap Chinese one. They are typically <$15 and they work just fine. I prefer getting the ones with the adjustable mixture screw.
59ctd is offline
post #7 of 9 Old 12-12-2019, 04:12 PM Thread Starter
I got a new carb for $13.09 with free shipping. Installed it, started the engine, adjusted the mixture screw, and grinned ear to ear. Can't believe I wasted so much time trying to clean and adjust the old carb. I have another Tecumseh running poorly and surging so, I ordered another new carb for that one too. Thank you guys for the help. gregjo1948
post #8 of 9 Old 12-12-2019, 05:15 PM
Thanks (Received): 212
Likes (Received): 767
I don't bother putting much time into cleaning anymore.....I have several 8-10 hp carbs on the shelf all the time and at least one 5-7 hp carb....
cranman is offline
post #9 of 9 Old 12-12-2019, 08:15 PM
orangputeh's Avatar
Thanks (Given): 763
Thanks (Received): 236
Likes (Given): 1584
Likes (Received): 1680
I hate waste so take the time to clean OEM Honda carbs. works almost every time.
but that's just me cause I have the time.
for most other people I agree that a new carb is time saving.
"It Feels Like Beer O'Clock "
orangputeh is online now
