Hand Crank vs Electric Start. Why doesn't it always turn manually? - Snowblower Forum : Snow Blower Forums
post #1 of 21 Old 01-07-2020, 11:52 AM Thread Starter
Dannoman's Avatar
Thanks (Given): 13
Thanks (Received): 19
Likes (Given): 50
Likes (Received): 124
Most of the time my old Tecumseh starts no problem with one or two pulls. But on colder days - or days it has not been in service for a while - I sometimes need to resort to using the electric starter. This might be a silly question but why is that?
Dannoman is offline
post #2 of 21 Old 01-07-2020, 12:05 PM
e.fisher26's Avatar
Thanks (Received): 52
Likes (Given): 44
Likes (Received): 71
Expansion/contraction of metal of the carb or gas changing in cold
e.fisher26 is online now
post #3 of 21 Old 01-07-2020, 12:10 PM
oneacer's Avatar
Thanks (Received): 149
Likes (Received): 540
All my 5 gal. gas cans immediately get Stabil and half the rate of SeaFoam.
Also, these small engines should be using a Full Synthetic 5W30 motor oil.
My machines start fine in cold or warm weather.
Note also, use the primer and choke properly.
You could also have many other issues, i.e., bad plug, bad wire, clogged fuel line, etc., etc....
oneacer is online now
post #4 of 21 Old 01-07-2020, 12:45 PM
ou2mame's Avatar
Thanks (Received): 7
Likes (Received): 45
yeah i'm assuming either its a gasoline problem, or a carb problem since it does run fine once started. So clean your carb and make sure you use a fuel additive.
ou2mame is offline
post #5 of 21 Old 01-07-2020, 02:00 PM
Thanks (Given): 587
Thanks (Received): 767
Likes (Given): 4352
Likes (Received): 1734
How old of a Tech ? Does it have a primer bulb and have you checked to see if maybe the primer line has deteriorated ? Usually starts to disintegrate at the carb. The fuel breaks the rubber down.
Likes DuffyJr liked this post
post #6 of 21 Old 01-07-2020, 04:22 PM
Thanks (Given): 26
Likes (Given): 85
Likes (Received): 252
The old Tecs I had didn't have a bulb primer - they had that push button and plate system, which, while it worked, basically was a PITA. That, and the old Tec recoil starters were plastic, and broke if you looked at them funny . . . So yes, the electric will do better simply because it moves more air and can pull more charge in to get things going more quickly - and I don't think any amount of cleaning or tuning can alter that - you just plain can't keep it spinning (or at the same speed) with the recoil as the electric.
What we were told years ago (and has never failed me) on these old L heads is to go to full throttle, switch on (if you have one), choke *OFF*, hit the electric starter, and then with it running, flip the choke to full until it fires, and immediately back it off a position or two. Started every time in 1 to 2 seconds, no matter the temp, and reduces the risk of flooding vs. starting with full choke.
So, in my experience, I call it normal . . . .
tadawson is online now
Thanks RedOctobyr, jrom thanked for this post
Likes RedOctobyr, Kiss4aFrog liked this post
post #7 of 21 Old 01-07-2020, 04:24 PM
Likes (Received): 22
https://www.youtube.com/watch?v=UQnxze7Hnhg
Amazing how much easier they start when that primer bulb is in working order. DonBoy never ceases to amaze me at how thorough he is.
1996 MTD 5/22
2016 Toro 721 QZR
DuffyJr is offline
post #8 of 21 Old 01-07-2020, 04:31 PM
Thanks (Received): 212
Likes (Received): 767
I drill a hole in my carb cover just in front of the carb...big enough to put a straw from a carb cleaner can. ( no electric in my shed). half choke,,,,one squirt....pull the recoil....fire in the hole!....why work hard????
cranman is offline
Likes Kiss4aFrog, jrom liked this post
post #9 of 21 Old 01-07-2020, 05:12 PM
Likes (Given): 1878
Likes (Received): 661
I have a hard time starting any of my 8hp snowblowers when the motor is cold but it is me and not the machine, most times I can't get the motor turning fast enough using the recoil and have to use the electric start. once the engine is warm it gets a little easier to use the recoil to start the engine
post #10 of 21 Old 01-07-2020, 06:37 PM
Thanks (Given): 587
Likes (Given): 4352
Same here. That's why I spend the extra couple bucks for synthetic oil. Seems when it's well below zero it helps to let the engine turn over faster. Easier on the arm
I rarely use the electric start but when you're worn out and looking at a driveway full of snow it's sure nice to have.
Likes Grunt, Huntergreen, detdrbuzzard liked this post
