Paddles wearing down - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-17-2020, 08:32 PM Thread Starter
Likes (Received): 22
Just some observations on my first SS and the paddles. I noticed I've reached the wear hole but it actually seems to be working better as far as gripping and pulling itself thru situations where it didn't do so well before like smaller EOD's and packed snow where I've had to blow the snow ahead and then re-blow it off to the side. It also is breaking up the tire tracks better where the car has driven. It also seems to blow just as far so I wondering how much further do you guys go once you hit the wear mark? I'm sure I can get thru the rest of the season but would rather change them out when it's not so cold like this summer.
1996 MTD 5/22
2016 Toro 721 QZR
DuffyJr is offline
post #2 of 5 Old 01-17-2020, 10:40 PM
Thanks (Given): 79
Thanks (Received): 83
Likes (Given): 330
Likes (Received): 362
I believe some automobile tires give better performance as they wear down but your worn paddle observations are surprising. New paddles have a larger outer diameter than worn ones and should in theory offer more propulsion and throwing ability.
1989 John Deere 1032
tdipaul is offline
post #3 of 5 Old 01-18-2020, 07:43 AM
Thanks (Given): 178
Likes (Given): 466
Likes (Received): 1045
Don't be overly concerned. When they wear down enough you'll be pushing that blower through all the snow it missed.
post #4 of 5 Old 01-18-2020, 08:10 AM Thread Starter
After thinking about it some more the only thing I can deduct is the paddles aren't flexing as much the shorter they get causing it to bite better. I did notice it's not cleaning down to the pavement quite as good.
My next question would be are the extended life paddles worth the extra cost?
1996 MTD 5/22
2016 Toro 721 QZR
DuffyJr is offline
post #5 of 5 Old 01-18-2020, 01:25 PM
Thanks (Given): 20
Thanks (Received): 35
Likes (Given): 59
Likes (Received): 219
I wouldn't worry about it. the paddles will wear down with the scraper.
Monitor the scraper and when it needs changed change both.
The only thing that matters is the gap between the paddles and the pavement and the back of the bucket. Once that gets too big the performance will suffer.
Sent from my SM-G950U using Tapatalk
Toro 621 6hp 4 cycle ....Craftsman SS ???
....Honda HS624 GX160 Toro 828 lxe Tecumseh 8hp
Snowbelt_subie is offline
