New snowblower fuel switch not working - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 01-18-2020, 05:09 PM Thread Starter
Hey guys, new to the board and new to snow blowers. I have a brand new Husky ST224P and I tried to stop it from running by turning off the fuel switch. It kept running and eventually I **** it off by pulling out the red safety key. Bad switch? What do you think?
Jrkba01 is offline
post #2 of 9 Old 01-18-2020, 05:10 PM Thread Starter
Must have type something else by accident... meant to type “shut it off”
Jrkba01 is offline
post #3 of 9 Old 01-18-2020, 05:19 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 424
Likes (Received): 664
it takes longer than you may think for the carb to run dry! how long did you let it run before you shut it off ?
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #4 of 9 Old 01-18-2020, 05:34 PM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
a rookie mistake.
after the fuel valve is shut off, it should take about 30-60 seconds before the fuel inside the bowl is used up.
db130 is offline
post #5 of 9 Old 01-18-2020, 05:44 PM Thread Starter
I let it run a minute or two. I’ll try again.
Also, i slightly over filled the oil. Is that an issue? I used it on light snow for about 15 min
Jrkba01 is offline
post #6 of 9 Old 01-18-2020, 05:48 PM
Thanks (Given): 59
Thanks (Received): 72
Likes (Given): 58
Likes (Received): 183
slightly, no issues............but what is slightly too much
MY VIDS ON FIXIN HER UP
vinnycom is offline
post #7 of 9 Old 01-18-2020, 06:52 PM Thread Starter
Maybe 3oz or so.
16oz capacity according to the manual. It was only half way up the dipstick from the factory. I filled it up a little at a time but ended up going over. Hard thing is of course that my garage is slightly pitched so it’s hard to get a flat reading. Driveway slopes as well
Jrkba01 is offline
post #8 of 9 Old 01-18-2020, 07:59 PM
Thanks (Given): 176
Thanks (Received): 344
Likes (Given): 481
Likes (Received): 850
I don't know how critical the "full" mark is, like how much leeway you have before it's a problem. But over-full is bad. The oil can get foamed up, and won't lubricate properly. If it were me, I'd feel better draining just a bit of oil out, until it's within the marks.
Depending on the RPM, it may take a minute or so to run itself dry. Give it a few minutes and see if it dies. At idle, mine probably runs for around a minute before it dies.
post #9 of 9 Old 01-18-2020, 09:32 PM Thread Starter
Thanks for the replies.
I drained a bit out via the dipstick. I used a plastic cup and tilted the machine. It wasn’t much so I’m not to worried.
I did end up getting it to turn of via the fuel shutoff, I’d say it took 3 minutes to stop.
Jrkba01 is offline
