Torque spec for Predator Engine crankshaft pulley - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 01-26-2020, 10:19 AM Thread Starter
Thanks (Given): 37
Thanks (Received): 70
Likes (Given): 116
Likes (Received): 146
I know I've seen it posted before, but came up empty using the search feature.
What's the torque spec for the 5/16"-24 bolt connecting the drive pulley to the crankshaft?
Also what's the best way to hold the pulley's when torquing the crank pulley to prevent putting stress on the engine internals while tightening?
Thanks!
2009 Honda HS928WAS
2005 Honda HS520AS
1996 Honda HS621AS
2012 Toro 1800 Power-Curve
Freezn is offline
post #2 of 3 Old 01-26-2020, 10:47 AM
Thanks (Received): 148
Likes (Given): 215
Likes (Received): 305
There are standard torque charts when nothing is published.
I've shoved a length of 1/4 inch rope into the spark plug hole a time or two when I needed the engine to not rotate.
dbert is offline
post #3 of 3 Old 01-26-2020, 11:16 AM
Thanks (Received): 23
Likes (Given): 41
Likes (Received): 47
torque spec will be dependent on application. you can always slide a screwdriver through the starter cup and tighten it that way
arienskids is offline
