A few teaspoons of gas line anti freeze? - Snowblower Forum : Snow Blower Forums
post #1 of 27 Old 01-28-2020, 01:07 PM Thread Starter
Thanks (Given): 273
Thanks (Received): 15
Likes (Given): 99
Likes (Received): 71
A friend of mine mentioned that his snowblower using buddies all recommend using a few teaspoons of gas line anti freeze in your tank. Sounds right. Anything to recommend against it?
2017 Toro PowerMax 826OE
barney is offline
Thanks Fat City thanked for this post
Likes Fat City liked this post
post #2 of 27 Old 01-28-2020, 01:20 PM
Thanks (Given): 68
Thanks (Received): 30
Likes (Given): 147
Likes (Received): 99
Unless your using old summer fuel, you won't have to add anything. Even then, unless it's - 40 or so you won't have to worry
Sent from my SM-G973W using Tapatalk
Doin things n stuff.
_________________________
2017 Husqvarna ST330P
1998 Craftsman 10/28 tracked
1980 Toro 11/32
SAVAGE420 is offline
post #3 of 27 Old 01-28-2020, 01:43 PM Thread Starter
Thanks (Given): 273
Likes (Given): 99
I believe his/their contention was that you often get a little water in the gas directly from the gas station. I was blowing snow in -26 celsius recently....I'm thinking that might be cold enough.
In anycase I've been meaning to pickup a bottle of that K100 stuff after seeing Donyboy recommend it.
barney is offline
Likes SAVAGE420 liked this post
post #4 of 27 Old 01-28-2020, 01:59 PM
Thanks (Given): 68
Likes (Given): 147
Well it definitely wouldn't hurt.
Let us know the results
1980 Toro 11/32
post #5 of 27 Old 01-28-2020, 02:06 PM
Thanks (Received): 82
Likes (Given): 76
Likes (Received): 287
i don't worry about gas line antifreeze. i usually just keep fresh gas on hand. never had an issue yet.
yardworks 31AH6WKF515
crazzywolfie is online now
post #6 of 27 Old 01-28-2020, 02:49 PM
Thanks (Received): 14
Likes (Received): 80
You need to check your regions fuel setup. Many cold areas go to a winter blend that has Ethanol in it for emissions purposes. If you get your fuel in the winter you are covered.
It also works as picking up some water (a slug will not be removed) and for a carburated machine its a carb ice preventer.
1998 YT624 Have Owners and Service Manual, Rubber Disc Drive (not hydrostatic)
RC20 is offline
post #7 of 27 Old 01-28-2020, 03:03 PM
Thanks (Received): 32
Likes (Received): 75
K100 can make sense for those who leave their snow blowers in below freezing conditions. However, K100 will eliminate water equal to itself and it's not likely a snow blower gas tank will have a few teaspoons of water.
Tony P. is offline
Thanks barney thanked for this post
post #8 of 27 Old 01-28-2020, 03:42 PM
Likes (Given): 28
Likes (Received): 41
I use ethanol free gas year around with no additives and have zero problems. My snowblower is kept in an unheated garage and I've blown snow in sub-zero (fahrenheit) conditions.
TooTall999 is offline
Likes Fat City, tuffnell liked this post
post #9 of 27 Old 01-28-2020, 04:00 PM
Sid
Thanks (Given): 10
Thanks (Received): 25
Likes (Given): 30
Likes (Received): 43
There used to be a product called "Dry Gas" mostly alcohol. Since they have been putting methanol in the gas, I don't see it around anymore.
Sid
'66 Sears/Murray 26"
'71 Jakobson 17 SnowBlitz
Sid is offline
post #10 of 27 Old 01-28-2020, 04:01 PM
Thanks (Given): 197
Likes (Given): 197
Likes (Received): 10
I'd use a little fuel stabilizer to combat water . Gas has alcohol, you don't need more .
Fat City is offline
