opinions if this carb is too far gone - Snowblower Forum : Snow Blower Forums
post #1 of 21 Old 01-28-2020, 04:24 PM Thread Starter
Just curious if you think this carb is too far gone.
Seeb02 is offline
post #2 of 21 Old 01-28-2020, 04:35 PM
Thanks (Given): 79
Thanks (Received): 83
Likes (Given): 330
Likes (Received): 362
Remove the float bowl and take a pic of the main jet and float pivot pin area. Its when these areas corrode, thats the real killer
1989 John Deere 1032
tdipaul is offline
post #3 of 21 Old 01-28-2020, 05:24 PM
Thanks (Received): 26
Likes (Given): 120
Likes (Received): 98
Brother,you wouldn't believe how crusty some carbs can get and yet can be made usable again with some brushes,torch-tip cleaners,solvent and elbow grease.
I just overhauled my uncle's portable generator that his idiot stepson left sitting out in the rain all summer and fall full of E10 fuel.That carburetor inside was just a mass of corrosion-I had to pull the inlet needle out with sidecutters.I was able to completely clean it using the items mentioned above and it ran perfectly.Engine was a Chinese copy of a Honda GX-200.Those carbs are a bit more forgiving than Tecumseh's in my opinion,but you get the point.
Mike C. is online now
post #4 of 21 Old 01-28-2020, 06:15 PM Thread Starter
The lower dark spot is a void. Looks like it goes all the way across and would let air in. Hard to believe it would seal properly.
Seeb02 is offline
post #5 of 21 Old 01-28-2020, 06:56 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 424
Likes (Received): 664
clean the voids, add some liquid metal, smooth it out and bobs yer uncle.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #6 of 21 Old 01-28-2020, 07:06 PM
Thanks (Given): 97
Likes (Given): 76
Likes (Received): 463
I find it challenging to find ways to bring parts back to life.
I would sand on a thick piece of metal, use JB Weld, file and sand again using Emory cloth, maybe a flap disk would work the best, then make my own gasket using a thicker piece of cardboard.
JLawrence08648 is offline
post #7 of 21 Old 01-28-2020, 08:15 PM
orangputeh's Avatar
Thanks (Given): 763
Thanks (Received): 236
Likes (Given): 1584
Likes (Received): 1679
agree . have brought old Honda carbs back to life like this one. it was the challenge that was the fun part.
"It Feels Like Beer O'Clock "
orangputeh is online now
post #8 of 21 Old 01-28-2020, 09:00 PM
Thanks (Given): 176
Thanks (Received): 344
Likes (Given): 481
Likes (Received): 850
JB Weld was my thought too, if there really is a void connecting one area all the way to another. I confess I can't see where the void is from the picture.
But you'd just need to obstruct the leak. There's no pressure involved, really, so just anything to fill up and seal the opening should do it. I would not use silicone, it does not handle gas. But JB Weld is OK with gas, once it's dried.
I think I'd do the smoothing by hand, rather than using a flap disk on a grinder, personally. Take too much off, or accidentally grind a gouge into the sealing surface, and you've just created another problem. You could smooth the JB Weld until it's just a little bit taller than the surface, before it hardens. That would reduce the amount of sanding you'd have to do.
post #9 of 21 Old 01-28-2020, 10:05 PM
Thanks (Received): 82
Likes (Given): 76
Likes (Received): 287
i feel like the gasket would likely seal that up
yardworks 31AH6WKF515
crazzywolfie is online now
Likes tadawson, Shaw351, 87powershiftx2 liked this post
post #10 of 21 Old 01-29-2020, 07:13 AM
Thanks (Given): 19
Thanks (Received): 99
Likes (Given): 747
Likes (Received): 268
with out any doubt it would,yet for safety i would apply a very thin light coat of permatex ultraseal to the carb side of the gasket .
87powershiftx2 is offline
