Tire Changer? - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 01-29-2020, 11:30 AM Thread Starter
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
Tire Changer?
After Wrestling with a pair of Tires, I looked and Found a Small Tire Changer from HF. Anyone Used One?
"Thank You Mr. Know it All!"
Jackmels is offline
post #2 of 11 Old 01-29-2020, 11:37 AM
Thanks (Received): 150
Likes (Received): 543
I have had the Mini-Tire Changer from Harbor Freight for years now …. Made changing tires a breeze … I hoped you used your 25 or 20 % off coupon.
oneacer is online now
post #3 of 11 Old 01-29-2020, 11:49 AM
Here it is ….
post #4 of 11 Old 01-29-2020, 12:06 PM Thread Starter
Likes (Given): 469
Thanks for the info.
Jackmels is offline
post #5 of 11 Old 01-29-2020, 01:02 PM
Thanks (Given): 174
Thanks (Received): 342
Likes (Given): 480
Likes (Received): 849
Oh interesting, you can clamp it to a workbench? That's cool. I assumed it needed to be bolted to the floor or something.
It's something I would use very rarely. But with a coupon taking it to ~$30, it might still beat wrestling with them "by hand" (I've had to put tubes in all 4 tractor tires, it was no fun). Especially if it could be stored out of the way somewhere.
post #6 of 11 Old 01-29-2020, 01:07 PM
Thanks (Received): 32
Likes (Received): 75
Interesting that a mini tire changer may be popular. I have several pieces of equipment that use tires and hubs but still don't find myself replacing at least one tire every year so I don't use a tire changer. Instead, I use tire changer hand tools like spoon levers I accumulated over the years.
Tony P. is offline
post #7 of 11 Old 01-29-2020, 01:45 PM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2045
Likes (Received): 517
+1 on the HF tire changer Jack.
I also use a good lubricant from NAPA
^^^ put that stuff in a spray bottle.
sometimes the bead sealer comes in handy (I don't use tubes):
and a schrader valve core removal tool...also handy for pulling stems through the hole.
^^^ take that puppy out when you're setting the bead for the maximum rush of air using a tapered air nozzle...also speeds-up deflating tubes to get them out.
('87 Toro 38150 826)
classiccat is online now
Post Thanks / Like - 0 Thanks, 4 Likes, 0 Dislikes
Likes Jackmels, Grunt, toromike, aldfam4 liked this post
post #8 of 11 Old 01-29-2020, 01:55 PM
Likes (Given): 46
Likes (Received): 52
I clamp mine in a vise.
1997 Toro 724
1997 Toro 824XL Power Throw
toromike is online now
Likes Jackmels, classiccat liked this post
post #9 of 11 Old 01-29-2020, 04:28 PM
Thanks (Given): 33
Thanks (Received): 66
Likes (Given): 116
Likes (Received): 138
I must confess on the real small wheels I take em to the tire shop. When the rims are under eight inches I begin to struggle with them... I now have tubes tossed in them as well.
I pay for the tube.. they put it in... They aren't making much money off me .. I expect they make decent profit on the tires though.. My tire guy is good to me.
He don't charge for flats on tires purchased there either... I buy the tubes anyway to save the headache later of a possible leak around the bead.. win win for me.. and win win for the tire shop
Shovel is offline
Likes contender liked this post
post #10 of 11 Old 01-29-2020, 05:15 PM
I only use a tube if there is something like a damaged bead or checked tire, or using a split rim … otherwise, I clean and paint, and put in a new stem on the rim … using tire sealant and bead sealer also helps greatly on installing/uninstalling tires with the mini tire changer.
Whereas I am always working on blowers, this mini tire changer has been invaluable over the years.
