engine cutting out when covered with blowing snow - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 01-29-2020, 04:58 PM Thread Starter
john Deere 928e, cuts out when blowing off the driveway only when the wind is blowing snow back at me and covering the machine. Im assuming i have a cracked coil or spark plug wire, and its grounding out when it gets damp. does anyone have any other ideas? this is my starting point....new coil is $27.00... not bad...
post #2 of 10 Old 01-29-2020, 05:14 PM
Thanks (Received): 28
Likes (Given): 143
Likes (Received): 57
Welcome to the SBF from Gettysburg.
2019 Ariens Compact 24...
penna stogey is offline
Thanks [email protected] thanked for this post
post #3 of 10 Old 01-29-2020, 05:39 PM
Thanks (Received): 8
Likes (Received): 27
Hi Klem:
Mine will sometimes act the same way however, I believe it is the snow being sucked into the air intake at the carburetor (even had it to it to my current EFI machine)
Robert
bbwb is offline
Likes [email protected] liked this post
post #4 of 10 Old 01-29-2020, 07:27 PM
Thanks (Given): 175
Thanks (Received): 342
Likes (Given): 481
Likes (Received): 850
Welcome to the forum! I suppose it could also be a bad insulator on the spark plug. Replacing the plug is at least a cheap and easy place to start.
I've never tried it. But you might be able to test by spraying a water mist (from a spray bottle) onto the ignition wire, etc, while it's running. To better understand where the problem is located, at least.
Likes [email protected], barney liked this post
post #5 of 10 Old 01-30-2020, 02:05 AM
Try cleaning everything (wiring/cap) then apply a silicone spray.
Nordic is offline
Thanks k[email protected] thanked for this post
post #6 of 10 Old 01-30-2020, 02:16 AM
Thanks (Given): 202
Thanks (Received): 126
Likes (Given): 421
Likes (Received): 266
Carburetor icing is one thing, another is getting water on any of the wiring for the ignition kill switch, down on the side of the engine. If it gets wet it could short out and ground your ignition, a possibility, besides shorting out a bad spark plug wire and cap.
ST1100A is offline
post #7 of 10 Old 01-30-2020, 06:37 AM Thread Starter
Great Information from all! Thank y'all! I learned where to look first for some simple problems, before I rip it apart.
post #8 of 10 Old 01-30-2020, 08:34 AM
Thanks (Given): 14
Likes (Received): 20
Removing the spark plug once it died and see if I still spark when cranking it (replug the wire) would give you an idea. (Make sure the tread of the plug contact with the engine block for grounding to test spark)
Also, if it’s carb icing on the jet you’ll have a very lean/hot plug signs.
If it’s spark problem or icing at the car air intake you’ll have a very wet plug.
You can try to see if choke help you keep the engine alive .. yes (frozen jet) if worst (frozen carb air intake). If no changes (more likely spark issue)
I like the previous suggestion of spraying a mist of water on the spark wire and coil..
Envoyé de mon iPhone en utilisant Tapatalk
Spawn.Qc is offline
post #9 of 10 Old 01-30-2020, 08:59 AM
Thanks (Received): 151
Likes (Received): 547
Slight possibility of blocking the gas cap vent, especially if it is already questionable. ….
oneacer is offline
post #10 of 10 Old 01-30-2020, 09:15 AM
Thanks (Given): 175
Likes (Given): 481
How exactly it dies would be useful to know. Is it like you turned the ignition off? Or starts sputtering, etc, and eventually dies, like running out of gas?
