Adjustable carburetor in new 1999 tecumseh 9hp - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 02-11-2020, 08:13 PM Thread Starter
Likes (Given): 88
Likes (Received): 17
Noob question.
My Yard man 927 has a dirty non adjustable carb, varnish, bowl edge under ring is pitted, ring is hard, runs a bit ruff, but I want to change it.
I want to know if I can install a brand new adjustable carb without any hassle ?? Will it run exactly the same or even better ??
I'm sure it's an easy question for experienced guys, that's why I'm asking.
Also why did they start installing non adjustable carb, just saving money ??
1999 Yard man 9 27 31AE653G501 with impeller mod
squid3083 is offline
post #2 of 13 Old 02-11-2020, 08:31 PM
Thanks (Given): 13
Thanks (Received): 126
Likes (Given): 147
Likes (Received): 297
Yes you can BUT you need to adjust it lol. The reason adjustable carbs went away way the emissions had to meet certain levels and that meant run lean and the gooberment did not want us making them run richer so they passed laws that they can’t sell adjustable carbs on the engines but fortunately you can get them aftermarket.
Dauntae is online now
Thanks squid3083 thanked for this post
post #3 of 13 Old 02-11-2020, 08:35 PM Thread Starter
Likes (Given): 88
Small adjustment I'm used to it, no problem. Start 1 1/2 turn on both then adjust idle and fast for good steady rhythm.
Thanks, will buy with adjustment in a kit if available, other separably.
post #4 of 13 Old 02-11-2020, 09:06 PM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
I've replaced several fixed jet carbs with aftermarket ones.
db130 is offline
Likes squid3083 liked this post
post #5 of 13 Old 02-11-2020, 09:49 PM
Thanks (Given): 26
Likes (Given): 85
Likes (Received): 252
Originally Posted by squid3083 View Post
Noob question.
Frankly, sounds like it would come right back with a cleaning and an O ring . . .
tadawson is offline
post #6 of 13 Old 02-11-2020, 09:58 PM Thread Starter
Likes (Given): 88
yes it would, buying stuff for cleaning and replacing rings, needle bowl gasket the whole thing in my spare time, but for less then $20 just want to install a brand new one, for this winter and will play with it afterwards.
With the snow we have around this time at 6 to 12 inches per shot, don't want to shovel.
Still replacing belts, bearings, did a lot of work on it, and not finished. will do the rest this summer
post #7 of 13 Old 02-12-2020, 12:11 AM
Thanks (Received): 14
Likes (Received): 80
Not up to speed on yours but a lot of non adjustable stuff had caps or plugs and remove those and .......
Not sure new carbs available for blower that era. Quick clean up and see for now might be a better option.
1998 YT624 Have Owners and Service Manual, Rubber Disc Drive (not hydrostatic)
RC20 is offline
post #8 of 13 Old 02-12-2020, 11:23 AM Thread Starter
Likes (Given): 88
Yes they are available.
If I clean it and oring swells up and gets blocked, I'm f^^%%d and don't want to stress and shovel.
post #9 of 13 Old 02-12-2020, 11:25 AM Thread Starter
Likes (Given): 88
Do you mean trasnforming a non adjustable carb into an adjustable carb with replacing needle on side and bottom jet ??
post #10 of 13 Old 02-12-2020, 02:56 PM
Thanks (Given): 26
Likes (Given): 85
The last Tec kit I bought (last year) had everything, and was about $13.00 from a dealer, and about 30 minutes to do the clean . . . and you have not indicated that you need the full kit, so I still don't get it . . . sorry! Seems like you would be far more likely to spend more time fighting Chinese junk parts than that . . .
tadawson is offline
