Ariens 32" and new Predator engine. - Snowblower Forum : Snow Blower Forums
post #1 of 18 Old 02-18-2020, 04:06 PM Thread Starter
I just picked up this old 32" Ariens and it seems a little underpowered with the stock 8hp Tecumseh. I really like the snowblower and was thinking about putting in an 8hp (can currently get for about 200$) or 13hp (299$ right now with coupon). Will the new 8 be underpowered still? Any input would be appreciated.
Also is there a different output from on these whereas I would have to adjust the pulley size accordingly?
aedude006 is offline
post #2 of 18 Old 02-18-2020, 04:55 PM
Thanks (Given): 33
Thanks (Received): 66
Likes (Given): 116
Likes (Received): 138
I would spend the extra 100... Rather than always wonder later if you should have went with the larger engine
If you go with the larger engine you have some power to spare and can increase your impeller speed while you are there
Shovel is online now
Likes detdrbuzzard, RedOctobyr liked this post
post #3 of 18 Old 02-18-2020, 07:16 PM
Thanks (Given): 48
Thanks (Received): 248
Likes (Given): 145
Likes (Received): 501
For a 32" auger, definitely go for the larger 420cc engine!
tabora is offline
post #4 of 18 Old 02-18-2020, 07:49 PM
Thanks (Received): 14
Likes (Received): 80
1000% agreed. 8 hp for a 32 inch is pathetic. I have that on a 24 inch machine (and its got torque to 10 hp levels)
All a new 8 hp will get you is the current sad level.
I am shocked anyone offered 8 hp 32 inch. Years back that was standard for 26 inch.
1998 YT624 Have Owners and Service Manual, Rubber Disc Drive (not hydrostatic)
RC20 is offline
post #5 of 18 Old 02-18-2020, 08:01 PM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
I modded a 32" 73-4 10000 Series with a 10hp Tecumseh, Impeller Seal, Larger Pulley and Chute Upgrade. She's Not Pretty, but Throws 30+ Feet.
"Thank You Mr. Know it All!"
Jackmels is offline
post #6 of 18 Old 02-19-2020, 07:16 AM Thread Starter
Thanks for all the input, the decision is clear. I did just fix up a 10/24 MTD that has the 10hp Tecumseh. I thought about swapping that, but I can sell that for anout what the predator engine costs right now..
post #7 of 18 Old 02-19-2020, 07:21 AM Thread Starter
I'll look into some of those other upgrades Jackmels along with lighting and maybe hand warmers just because I can put them on... I'm assuming with the more power I will also have to adjust my drive speed, this is probably done by adjusting the friction wheel?
post #8 of 18 Old 02-19-2020, 07:34 AM
Likes (Given): 469
The MTD Double Shaft Engine Won't Work on the Ariens. Find a 10hp Tec with a 1" Crank. It is a Straightfoward, Easy Engine Swap. The Larger Predators Have a Different Footprint, and will need Redrilling of Mounting Holes to Fit Your App.
Jackmels is offline
post #9 of 18 Old 02-19-2020, 07:51 AM
JnC
Thanks (Given): 69
Thanks (Received): 144
Likes (Received): 234
Find a used Honda GX390 motor off of craigslist or marketplace, those should work and they are bulletproof. A used one off of a waster powerwasher can be had for as little as $50. I have bought a couple at that price.
JnC is online now
post #10 of 18 Old 02-19-2020, 07:57 AM
Thanks (Received): 35
I would go with the 13hp. I think the 8 will be under powered. I have an 11hp on my 26 and its a monster.
CarlB is offline
