Squeek when Auger Handle is squeezed - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 02-23-2020, 03:16 PM Thread Starter
Thanks (Given): 250
Thanks (Received): 46
Likes (Given): 733
Likes (Received): 135
Hi Members,
We've had a very uneventful winter so far here in the Northeast. It was 45 degrees here today and sunny. I decided to pull out my Ariens 924 and let run for awhile. I noticed when I squeezed the right auger handle I get a quick squeak (about a second) and it sounds like it is coming from the belt cover area. It is hard to discern because the engine is running. I made a 10 second video but not sure how to get it on the forum. I was wondering if it may be the auger bearing/belt but not sure and I believe I can get by until the summer. Everything seems tight on the rakes and shaft. Any thoughts..., thanks.
Tim
Ariens - 924086 - ST1028
Craftsman - 88934 - 10HP 28"
Toro - CCR 3650
Toro - CCR 2000
aldfam4 is online now
post #2 of 5 Old 02-23-2020, 03:51 PM
Thanks (Given): 33
Thanks (Received): 66
Likes (Given): 116
Likes (Received): 138
Originally Posted by aldfam4 View Post
Hi Members,
Tim
A chirp or squeak is normal is as the impeller has to be brought up to speed.
None the less..I would still remove belt cover and adjust if needed..
Also with the cover off it is much easier to find the noise ..It will slip briefly right at the crank pulley while it brings the impeller up to speed...a quick chirp or squeel is normal( second or less)
Some belts are quieter than others.
Check your idlers pulleys while there..a stiff idler can cause a little noise if it partially frozen as well
Shovel is online now
post #3 of 5 Old 02-23-2020, 05:47 PM
orangputeh's Avatar
Thanks (Given): 762
Thanks (Received): 235
Likes (Given): 1581
Likes (Received): 1667
you're working the mice too hard.
i agree with Shovel
"It Feels Like Beer O'Clock "
orangputeh is online now
Likes aldfam4, Shovel, 87powershiftx2 liked this post
post #4 of 5 Old 02-23-2020, 06:21 PM
Thanks (Given): 48
Thanks (Received): 248
Likes (Given): 143
Likes (Received): 500
It's just like the chirp when a plane's tires touch down and have to go from 0 to 80-150 MPH...
tabora is online now
Likes Shovel, 87powershiftx2 liked this post
post #5 of 5 Old 02-24-2020, 06:07 AM
Thanks (Received): 99
Likes (Given): 739
Likes (Received): 263
amen! i hear that every time i touch down. screech!
real world on a snow blower if it goes on for a long time, check the belts and adjustments .if only a second or two normal .
87powershiftx2 is online now
