Crankshaft Seal Lean on Brand New Briggs & Stratton 420cc - Snowblower Forum : Snow Blower Forums
Old 03-20-2020, 07:55 AM Thread Starter
Thanks (Given): 9
Likes (Received): 18
Iíve got a new B&S 420cc engine on a snowblower with about 18 hours on it and noticed a slight oil leak on the crankshaft seal on the PTO side. Itís still under warranty as it was purchased in Nov Ď19.
Itís a very slight leak but itís near the belts that drive everything.
Iím wondering how common this type of issue is. I thought I read that these engines are made in China and they had some quality issues with production there. I noticed the following thread on the same issue, same engine from 2014: https://www.snowblowerforum.com/foru...g-now-ugh.html
Does anyone have any recommendations, comments or similar experiences to share about this that might help me before I call the dealer?
ericr is offline
Old 03-20-2020, 09:11 AM
oneacer's Avatar
Thanks (Received): 147
Likes (Received): 535
A leaking crankshaft oil seal on a new engine still in warranty would be a concern for me that I would definitely have the dealer remedy.
I would imagine that exterior seal should be easily replaced from the exterior.
oneacer is online now
Old 03-20-2020, 09:38 AM Thread Starter
Thanks (Given): 9
I usually cringe at having to get work done in general. Maybe I'm a control-freak, but I've seen so many goof-ups getting things "repaired", only to have other things get broken, or put back together wrong.
Oh well I guess I'll call the dealer today...
ericr is offline
Old 03-20-2020, 04:06 PM
Likes (Given): 35
Likes (Received): 25
Check your oil, make sure your carb isn't leaking. I personally would look it over really well and do it my self, but I've done it before and have the tools. New engine everything should pop off and you get to put anti seize back on under the pto sheaves.
oneboltshort is online now
Old 03-21-2020, 06:10 PM
Likes (Received): 6
If you're still under warranty have them fix it. The leaking crankshaft seal is all too common with Briggs and Stratton engines it seems. I have a B&S generator with the 342cc engine and it has a leaky crank shaft seal, almost since new. It's not bad now so I live with it. This generator has a 10/2010 build date. While I worked at Lowe's there were many returned B&S generators, especially with the 305cc engine that suffered major or fatal crank shaft seal failures. Check on the internet you'll find examples of it in various OPE's with B&S engines. In my case the leak varied. I don't know why because I used B&S synthetic 5W-30 oil since new. As of now the leak is so minor and the generator operates so good I'll live with the minor oil seep/leak I have.
whimsey29 is online now
Old Yesterday, 04:58 PM
You can check it back with your manufacturer to see if that covers the warranty.
hertfordshire is online now
