When standing blower on end should you drain oil first? - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 03-16-2014, 10:49 AM Thread Starter
Big Ed's Avatar
Thanks (Given): 10
Thanks (Received): 19
Likes (Given): 9
Likes (Received): 59
I was watching some blower repair videos and in one it was said to drain the oil first, all of the time, before the machine is put up on the auger housing.
He claims that the oil could seep into areas of the motor that you don't want it in while it is up on end.
I never thought about this before.
What do you all think?
I try to make sure that the gas tank is near empty and hang a small pail from it, but I never gave a thought about draining the oil every time I stand it on end.
Overkill?
I hate shoveling SNOW!
22" Dual Stage
"Classic" 1963 S-226 Snowbird
22" Dual Stage
Big Ed is offline
post #2 of 15 Old 03-16-2014, 11:03 AM
Thanks (Given): 146
Thanks (Received): 325
Likes (Given): 430
Likes (Received): 778
My Tecumseh 8hp flathead and 10hp OHV engines have spent time in the service position. Bucket/nose down, wheels in the air.
Never gave me issues with either one.
However, I close the fuel shutoffs and run the carbs dry on my machines when I shut them down. So the carb doesn't drain onto the ground in this position. I also put a plastic bag over the fuel tank fill opening, then screw the cap on, to keep the gas from dripping out the vent. If there is not much in the tank, this may not be an issue.
With the 10hp OHV in this position for multiple days, I started to get a few drips of oil on the ground, from the governor shaft, I believe. So I put a plastic bag under that area. Make sure the dipstick is screwed in tight!
But it never gave me any trouble. If you put it back on the wheels and *immediately* started it, maybe that would do something weird, I don't know. I don't need to start them again that quickly, if I've just had them on the their noses.
post #3 of 15 Old 03-16-2014, 01:15 PM
Spectrum's Avatar
Thanks (Received): 40
Likes (Received): 149
I have B&S L heads on their nose regularly with no crank case issues. If you leave it there long enough you might discover a failing output crank shaft seal.
As for gas, you need to understand the fill level in relation to where the fill opening is when up. Sometimes you can use a thin plastic bag under the fuel cap to defeat the vent for short term work. Even the carburetors reset when they are back on the floor.
Pete
Spectrum is offline
post #4 of 15 Old 03-16-2014, 07:56 PM
These are handy tips. I was going to drain everything, including the radiator, before I tipped it up.
Pythons37 is offline
post #5 of 15 Old 03-17-2014, 06:42 PM
Likes (Received): 7
Standing the blower on end could hydrolock the motor, or so I suspect happened to my new to me blower. I will report back after investigating.
Overkill?
junkyard_sal is offline
post #6 of 15 Old 03-17-2014, 07:44 PM
Thanks (Given): 573
Thanks (Received): 749
Likes (Given): 4246
Likes (Received): 1679
Most snow blower fuel tanks seem to have the nipple for the fuel line at the back of the tank so when you have less than 3/4s of a tank the fuel nipple is up in the air and only the fuel in the line and bowl can possibly drain into the engine. Might be enough to cause a hydrolock. Best to make sure you're below 3/4s tank if you're going to tip it, better yet to have a fuel shut off and to run the carb out of fuel before you tip it up.
As for oil, if you tip it up and have it that way for a length of time then hopefully you will bring it back down to it's normal position for a day or two and the oil has a chance to drain back into the crankcase.
I haven't run into a problem with tipping them on mine. My only problem is my Estate's dipstick doesn't seal so I have to make sure to put a drain pan under it if I tip it up or I'll have a mess.
post #7 of 15 Old 03-18-2014, 11:57 AM
enigma-2's Avatar
Thanks (Received): 20
Likes (Received): 49
... I haven't run into a problem with tipping them on mine. My only problem is my Estate's dipstick doesn't seal so I have to make sure to put a drain pan under it if I tip it up or I'll have a mess.
Old style dipsitch I'm guessing. If it were me, I'd try pulling out the dipstick and put a cork in it. (Like a wine stopper, they're rubber and expandable to close the top of the wine bottle to prevent oxidation.)
example:
If the opening's around an 1-1/2-inch, you could use a thermos bottle cork (just guessing here, don't fault me for trying... :-)
2014 Ariens 24" Platinum
Toro CCR 3650 GTS
enigma-2 is offline
post #8 of 15 Old 03-19-2014, 10:35 AM
Question.....would making sure your piston is at TDC prevent a hydro lock?
AverageJoe is offline
post #9 of 15 Old 03-19-2014, 02:04 PM
pfn
Thanks (Given): 13
Likes (Received): 11
Ariens advised me not to store my machine in the service position. They said it put pressure on the seal. I can't imagine a quart and a half of oil could put much pressure on anything but there you go.
pfn is offline
post #10 of 15 Old 03-19-2014, 06:34 PM Thread Starter
Big Ed's Avatar
Thanks (Given): 10
Likes (Given): 9
You should have asked what they thought just for short term up on end to work on it. I was not talking about storing it up on end.
The guy in the video I watched says he drains the oil EVERY TIME he stands it up on the auger housing.
That is why I asked I wanted to see what the more experienced guys thought of this.
I have been doing it since I had mine, I see no ill effects.
But it is not standing up for long, maybe a half an hour at the most.
I never thought about storing it up on end all summer, I don't need the room.
Mine sits in the normal position all the time.
22" Dual Stage
22" Dual Stage
Big Ed is offline
