would this replace a series 3 carb? - Snowblower Forum : Snow Blower Forums
post #1 of 2 Old 10-17-2014, 01:41 AM Thread Starter
i found this carb for cheap. i know the primer bulb is in diff spot. but i dont see idle mixture screw and idle speed screw??? can i use this as a replacement for series 3 tecumseh
wantboost is offline
post #2 of 2 Old 10-17-2014, 11:05 AM
Grunt's Avatar
Thanks (Given): 259
Thanks (Received): 320
Likes (Given): 3160
Likes (Received): 636
That carb will NOT work on your 8 hp engine, it is a lawn mower carb. The correct part number carb you need is a Tecumseh 632334. I found this one on eBay. Those replacement carbs from China will not accept Tecumseh replacement parts if they ever need rebuilding in the future. Best to use original parts.
