Snow puddle containment - Snowblower Forum : Snow Blower Forums
post #1 of 33 Old 11-27-2014, 02:35 PM Thread Starter
guilateen02's Avatar
Thanks (Received): 30
Likes (Received): 110
Anyone have an inexpensive and affective way of containing all the melted snow off of a blower? I put my all purpose painters blanket under it. It just wasn't good enough.
guilateen02 is offline
post #2 of 33 Old 11-27-2014, 02:39 PM Thread Starter
This is the mess im left with.
post #3 of 33 Old 11-27-2014, 02:55 PM
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3335
Likes (Received): 679
I have a tray like this one and it does an excellent job of containing the water and preventing rust stains on the floor. You could probably find something cheaper to work. I also use a standard boot tray for my snow shovels. I also brush off all the snow I can with the machine out doors before parking it.
Lisle 19722 Catch-All Drip Pan: Motor Oil, Transmission Fluid & Car Lubricant : Walmart.com
post #4 of 33 Old 11-27-2014, 03:00 PM
Likes (Received): 1379
I think AREINS has a app 4 that also.
post #5 of 33 Old 11-27-2014, 04:01 PM Thread Starter
24 x 36 wont work. Ill have to look for a bigger one. I just measured and i would need 36x36. I am going to look at Granger. I have a feeling this is going to cost me a pretty penny. The 24 inch doesn't allow the wheels to be in the catcher. Also my bucket is 32 inches plus skids about 36.
post #6 of 33 Old 11-27-2014, 06:58 PM
Thanks (Received): 143
Likes (Received): 297
Could make a frame out of 2x2's, or what ever you have, that outlines the foot print of your machine, and simply drape a plastic tarp or plastic sheet over it. May want to make it a little bigger, so that you could actually elevate the machine out of the puddle, so as not to allow the machine to freeze to it.
post #7 of 33 Old 11-27-2014, 07:16 PM
Thanks (Given): 72
Thanks (Received): 397
Likes (Given): 182
Likes (Received): 928
Are you brushing off as much snow as you can before you park it?
I have minimal meltage..a tiny puddle that evaporates away quickly if
its above freezing in the garage.
post #8 of 33 Old 11-27-2014, 07:26 PM
a floor squeegee works and they are 20 bucks or so.
post #9 of 33 Old 11-27-2014, 07:51 PM
Likes (Received): 16
I clean off the machine the best I can out in the yard and then hose my machine after each use. So nearly no water to drip off in the garage. I rest the scraper blade on a 2 x 4 piece and no rust stain on the floor.
cdestuck is offline
post #10 of 33 Old 11-28-2014, 09:22 AM
Likes (Received): 8
I brush the bulk of the snow off then I use the air compressor to blow the rest of the snow off the machine. I get minimal melt off the machine as is sits in the garage.
JerryD is offline
