Stator Equipped? - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 11-30-2014, 11:36 AM Thread Starter
GMH
Likes (Received): 41
Stator Equipped?
How can I tell If my blower (simplicity 8560E1) has a stator to run lights without tearing it apart? There is no mention of it anywhere in my owners manual that I could find. There appears to be a black wire coming out of a hole in the casting near the fly-wheel. Could that be the feed? Thanks for any info.
ID:	28313   Click image for larger version
ID:	28321   Click image for larger version
GMH is offline
post #2 of 15 Old 11-30-2014, 01:56 PM
Likes (Received): 16
Put a multi meter I the wire while the engine is running. Check for both ac or dc voltage. Most times its ac but can be dc I think.
cdestuck is offline
post #3 of 15 Old 11-30-2014, 02:10 PM
Normex's Avatar
Likes (Received): 82
You may have to dig a bit deeper to find out, in your middle pic can you pull on the rubber boot and see if the wires are coloured like yellow?
And if so like cde mention check for ac voltage or dc with a needle like prong of course with engine running.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #4 of 15 Old 11-30-2014, 03:10 PM
Grunt's Avatar
Thanks (Given): 274
Thanks (Received): 330
Likes (Given): 3321
Likes (Received): 677
As others have stated, put a meter on the red connector and see what type of voltage you have and if it is AC or DC. I suspect it will be 12 volts DC at 5 amps output according to this Briggs illustration and the regulator you have hose clamped to the starter motor.
post #5 of 15 Old 11-30-2014, 03:55 PM
Grunts got it-that is a voltage regulator/bridge rectifier the red lead will be 12volt out. Make sure to not overload that circuit.
pweerc is offline
post #6 of 15 Old 11-30-2014, 04:04 PM Thread Starter
GMH
Thanks, that is exactly what I need. I am about to fire it up for a little cleanup and will check the red wire. If it is DC, I should be able to connect an LED light directly to it and not need the bridge rectifier mentioned in the "upgrade to LED Lights" sticky thread correct?
GMH is offline
post #7 of 15 Old 11-30-2014, 05:38 PM Thread Starter
GMH
OK. I am reading 13.8 volts +/- at the red wire at full throttle. How can I tell how many watts/amps I can draw?
GMH is offline
post #8 of 15 Old 11-30-2014, 05:59 PM
Grunt's Avatar
Thanks (Given): 274
Likes (Given): 3321
You can use your meter IF it has an amperage position- OR - You can trust the Briggs rating of 5 amps as shown in the illustration. The regulator in your picture is showing a capacitor which should mean voltage is filtered. Superedge and Coby are the electrical wizards in this regard and will hopefully chime in. Check the amp draw on the light(s) you plan on using and install an inline fuse holder with a fuse of 5 amps or less to protect the stator.
post #9 of 15 Old 11-30-2014, 06:53 PM Thread Starter
GMH
Thanks. the regulator/rectifier is part #698102, which seems to have been replaced by part #698315. I am trying to find specs on it, as the wire and plug colors coincide with a 5 or 9 amp regulated system according to an old B&S manual I have.
GMH is offline
post #10 of 15 Old 11-30-2014, 07:02 PM
Thanks (Received): 379
Likes (Received): 1377
YEAH that is set up for a light.
