John Deer 732 shear bolts - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 12-03-2014, 05:40 PM Thread Starter
New to the forum and snowblowers. I've always used a skid steer on my drive. I just purchased an old 732 that appears well cared for. I pulled the shear bolts out and they appear to be a standard bolt and were torqued pretty tight. The impellar shaft does not turn and appears to be frozen. I think the prior owner had a paved drive as it was set low. I'm thinking heating it up ? Any ideas ?
mikec49 is offline
post #2 of 4 Old 12-03-2014, 07:45 PM
Normex's Avatar
Likes (Received): 82
Welcome to the forum, could be a bearing issue did you try turning the impeller with the large pulley behind or pressing on impeller itself?
As for the auger bolts maybe for good insurance buy 4 new shear bolts as you'll have a set as spare.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #3 of 4 Old 12-03-2014, 07:56 PM Thread Starter
I wasn't clear. The impeller turns while running. It won't free turn with the bolts removed. I'm thinking it has siezed to the shaft so shear bolts wont do their job.
mikec49 is offline
post #4 of 4 Old 12-03-2014, 08:03 PM
Normex's Avatar
Ok I think you are calling the augers impeller, the impeller is the one that shoots the snow through the chute. Now with the bolts removed and it won't freewheel means that the shaft is seized to the auger tube.
So you will have to remove everything and apply pcblaster and heat to set them free.
Normex is offline
