Anyone Running Carlisle x-trac Tires - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 12-04-2014, 06:26 PM Thread Starter
If so, how do you like them? Traction, Wear , installation? I want to go from a 4 to 5 inch width, but the Carlisle site states I need a 3.5 width rim rather than 3.25 that I have. Anyone mounted a wider tire on the same rim without problems?
MTD 24 Tec 5.5 hp
Edge is offline
post #2 of 16 Old 12-04-2014, 08:23 PM
Thanks (Given): 172
Likes (Given): 450
Likes (Received): 1026
Sorry but I can't help. Hopefully someone will chime in soon. I don't believe I've seen any tire questions on here before. Most of the mods are impeller kits, lights, and pulley changes.
post #3 of 16 Old 12-04-2014, 08:50 PM
Likes (Received): 303
I swapped old turf type 4.10-350-6NHS tires to X-trac 13x5.00- 6NHS on '79 Ariens rims. I have not run them yet, still playing around with a motor mount plate to fit new power supply I can tell you I will likely pay someone next swap. The bead structure on X-trac is very strong. I have a HF small tire changer kit that I've used on lawn tractor tires with great success, Carlisle brand tires too. These x-tracs were tuff little buggers. My rims were bead blasted and repainted and were smooth as a babies bottom too. Perhaps 8" and bigger are that much easier.
post #4 of 16 Old 12-04-2014, 08:55 PM
Are you swapping the tires on the blower in your signature? If so I would look on your local CL for a set mounted on wheels. They show up a lot around here especially the pinned hub to axle type, bolt mount not so much.
post #5 of 16 Old 12-05-2014, 08:54 AM
Kielbasa's Avatar
Thanks (Received): 28
Likes (Received): 107
On my 1971 Ariens, I am running the Carlise (13 X 4.0 - 6) with tubes. These are an excellent tire for our machines. They are such an improvement over the original Goodyear tire. They have great traction. As far as wear, they have only been on for about five years so I can not really say, but I am sure that they will last my lifetime. I really do not see why you would need to go any wider. I keep them at about 18 LBS.
Kielbasa is online now
post #6 of 16 Old 12-05-2014, 12:27 PM Thread Starter
Yes , these tires are for the blower in my Sig. They are Snow Traks 4.10 x 6 that have the Snow Hog lug pattern. I can't find them easily online, probably an off brand and why they are cracking at the tread -That and the hard last winter. The wheels are bolt on, so not many on CL here.
I figured if I could go a little wider to 13-5 x 6 without problems with my 3.25 rim, they might give more traction and last longer. I'd don't how much better they will be but, I can't have leaks , rim slip or install problems. I'll be using 12 inch motorcycle tire irons for the install.
MTD 24 Tec 5.5 hp
Edge is offline
post #7 of 16 Old 12-05-2014, 04:55 PM
guilateen02's Avatar
Likes (Received): 110
The x trac are great tires. I just switchedy 73 ariens from a 6 wheels inch to the 8 inch wheels. Check Summit Racing for the tires. They had the best pricing for the Carlise X-trac. People are using these tire on atv and dirt bikes. If you want a bigger rim check for the Snapper Rear Engine Riders on CL. They have the same bolt pattern. Also many tire shops wont install small tire amd wheel combo. I tried Bennys,Firestone,Pep Boys,and a few others. Here is a few tips I've learned from my installs. Soak the tire in hot water. Lube the edges of rim and tires with dish soap. Use three stong long flat head screw drivers and two people. One to hold screw druvers in place while the other person pries the other two. Also i found that hair spray (aqua net) works great as a bead sealant. As for setting the bead. I won't say how to do it on here nut you can YouTube Red tire bead seal.
guilateen02 is offline
post #8 of 16 Old 12-05-2014, 05:12 PM
Ditto what quilateen said. Summit racing has the best price and they ship the tires with air pillows inside them so they're not smooshed. On a previous snowblower I used Kenda Polar Tracs from Northern Tool. Price was right, but they came smooshed with no packaging.
post #9 of 16 Old 12-05-2014, 07:37 PM
Just use tubes and then you don't have to worry about leaks or sealing beads.
post #10 of 16 Old 12-05-2014, 08:27 PM
I got them on mine. band new ones. They work great on any surface I've been on. Don't know the exact size off hand though. I thought I would have to put a chain or two on but not even close.
abycat is offline
