Skid shoes and ice scrapper adjustment? - Snowblower Forum : Snow Blower Forums
post #1 of 45 Old 12-07-2014, 10:07 AM Thread Starter
KaRLiToS's Avatar
Thanks (Given): 40
Likes (Received): 11
Yesterday I installed my front skid shoes and had to adjust the others because they were not adjusted correctly.
I now have a total of 4 skids shoes.
My ice scrapper is around 1/8" - 1/4" from the ground? Is that okay?
I don't want to scratch the pavement. I also know myself and that after the snowblower job, I'll remove the rest with a shovel.
KaRLiToS is offline
post #2 of 45 Old 12-07-2014, 10:47 AM
Big Ed's Avatar
Thanks (Given): 10
Thanks (Received): 19
Likes (Given): 9
Likes (Received): 59
It looks to be on the lowest setting you can go?
Can you even set it lower?
Is there a scraper bar on those too?
Like on my Craftsman the scraper bar adjusts.
Sure looks purrrtie all brand'ee new.
I can see you now, crying when the first oops scratch is embedded into the bucket.
I hate shoveling SNOW!
22" Dual Stage
"Classic" 1963 S-226 Snowbird
22" Dual Stage
Big Ed is offline
post #3 of 45 Old 12-07-2014, 10:51 AM Thread Starter
KaRLiToS's Avatar
Thanks (Given): 40
Yes there is a scraper bar. And no it is not set to the lowest, I still have some room.
Oh man, you seem to know me well. HAahah
KaRLiToS is offline
post #4 of 45 Old 12-07-2014, 10:54 AM
pwm
pwm's Avatar
I've got smooth concrete. I run my scraper bar touching the surface so that I don't leave any snow behind the blower. I've always done this and it does ware the scraper down over time. I gave my my old machine, which is almost 40 years old, to my son this summer. The scraper bar was quite worn down on the bottom side so as part of a general overhaul and repair job, I just rotated it 180 degrees and now a new side is facing the ground. It should last for another 20 years or so.
In my opinion, I would rather do a clean job, leaving no snow behind, and accept the wear on the scraper bar. The scrapers can be rotated, or if not they are cheap and easy to replace with new ones.
pwm is offline
Likes Hanky liked this post
post #5 of 45 Old 12-07-2014, 11:03 AM Thread Starter
KaRLiToS's Avatar
Thanks (Given): 40
That is some valuable opinion, thank you.
Do you notive any sign of scratching on the concrete?
KaRLiToS is offline
post #6 of 45 Old 12-07-2014, 11:59 AM
pwm
pwm's Avatar
The scraper does not leave marks. The steel skids might. I prefer the poly skids over steel. They slide better over concrete, wear as well as steel, and are cheaper to replace.
pwm is offline
post #7 of 45 Old 12-07-2014, 04:29 PM
Normex's Avatar
Likes (Received): 82
Karlitos first did you set up your skids with the snowblower on medium setting? if yes then to set it at exactly 1/8" take 2 toonys and place one of each under the scraper bar at each end. At this point you should see equal distance the whole length of scraper bar and just lower your skids to the concrete and tighten them and you're done. When you do something like this just ensure the surface is even and Good Luck.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #8 of 45 Old 12-07-2014, 05:23 PM Thread Starter
KaRLiToS's Avatar
Thanks (Given): 40
Yes I did that on medium. Thanks for all those tips. I havent adjust the scraper bar, I left it as it was by the dealer, I just reseated the back skid shoes because one was set higher than the other. I also paid attention if the floor was even.
As usual, thanks Normex
KaRLiToS is offline
post #9 of 45 Old 12-07-2014, 05:40 PM
tinter's Avatar
Thanks (Received): 25
Likes (Given): 81
Likes (Received): 39
Looks so shiny and new.
tinter is offline
post #10 of 45 Old 12-07-2014, 05:47 PM
Normex's Avatar
If it is difficult to adjust all 4 skids then maybe you should just use the front side skids and raise the back ones to keep them as spares.
Normex is offline
